ACE 4710 problem from server vlan
EngZiad
Community Member
Hello
I have configured load balancing for a small server farm of 2 oracle ERP servers ( servers accepting web requests on port 8000)
Design is routed mode where I have a client vlan and a server vlan , real servers default gateway is set to the alias ip address of the ace server leg ( actually we have 2 ace appliances with redundancy setup)
When we access the application from client vlan everything works fine but when we do the same from server vlan
We can not reach the application.
I need a hint to catch the problem . Can you help
ravi281278
Hi Ziad,
Server LAN IP pool needs to be PATTED in SERVER vlan.
Ravi  K. Sharma
Thanks my friend.
i need to pat all my server LAN (10.10.9.x)  pool to which IP?
is it to the VIP ( 10.10.7.254) ?
Ziad
Dear Ravi
i have patted the server LAN pool to one unused ip and it worked fine!.
many thanks!!!
Ziad Itani
