Cisco ACE and IIS Virtual Directories
mrthestuff
Hello All,
I have the Load Balancing between to servers working correctly except for on thing. If I enter www.domainname.com\apps into the browser it will returns a 302 page, but if I enter www.domainname.com\apps\ the page will Pull up. Is there a way for the ACE to add the \ after the Virtual Directory?
Jorge Bejarano
Level 4
Level 4
Hello Brian,
I guess you have something configured like this:
host1/Admin(config)# class-map type http loadbalance L7SLBCLASS
host1/Admin(config-cmap-http-lb)# 10 match http url /apps
But you should have something like this:
host1/Admin(config-cmap-http-lb)# 10 match http url /apps.*
Here you have a doc with additional info:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA3_1_0/configuration/slb/guide/classlb.html#wp1021430
Hope this helps
Jorge
Here is an example of the configuration:
rserver host NET01
  ip address 10.0.20.24
  inservice
rserver host NET02
  ip address 10.0.20.25
  inservice
serverfarm host NET-Farm
  predictor leastconns
  rserver NET01 80
  rserver NET02 80
    inservice
parameter-map type http HTTP_PARAMETER_MAP
  persistence-rebalance
sticky ip-netmask 255.255.255.255 address source NET-IP
  replicate sticky
  serverfarm NET-Farm backup Maintenance
class-map match-all NET
  2 match virtual-address 10.0.20.21 tcp eq https
policy-map type loadbalance first-match NET
  class class-default
    sticky-serverfarm NET-IP
    insert-http x-forward header-value "%is"
policy-map multi-match int71
class NET
    loadbalance vip inservice
    loadbalance policy NET
    loadbalance vip icmp-reply active
    nat dynamic 6 vlan 71
    appl-parameter http advanced-options HTTP_PARAMETER_MAP
interface vlan 71
no icmp-guard
  nat-pool 6 10.0.20.21 10.0.20.21 netmask 255.255.255.255 pat
