ACE 4710 redirect issue
ncfb-awarsame
Hi veryone
I trying to redirect http://www.ncfbins.com/myAccount  to https://www.ncfbins.com/myAccount, but it does not keep the value after /myAccount/
I want ACE to keep the part of url string after myAccount.  How can I do that?
thank you.
pablo.nxh
Level 3
Level 3
Hello buddy,
To keep the URI on the redirected request you need to use the %p parameter, try the following:
rserver redirect NCF
  webhost-redirection https://%h/%p
  inservice
__ __
Pablo
Thanks pablo,
https://%h/%p works if you keep the entire url. example  http://example.com/example/file is rewriten https://example.com/example/file.
I want the hostnae and first /string after hostname rewritten, but anything  after it to be kept.   for example:
http://example.com/example/file1 --------https://example.com/pablo/file1
http://example.com/example/file2 ------https://example.com/cisco/file2
I hope this make sense
thank you.
Hi pal,
I'm afraid that what you're trying 2 do is not possible You can't instruct the ACE to copy only a slice of the dynamic content
of the URI.
In your example we could set a static webhost redirection to be like: https://example.com/cisco/%p but the redirected URL will end up looking
like https://example.com/cisco/example/file2.
As you can see the ACE keeps all the string from the original request, that's what %p is designed to do.
Hope this makes sense and sorry to break the bad news =/
__ __
Pablo
It does and I have seen already.
Thank you pablo
