ACE 4710 - SSL issues 2 ViPS
dclee
Level 5
Level 5
Well I have struggled with our new ACE over the last few weeks but I think I am on my last issue
Currently have all inbound SSL termination working for *.english.ca
which uses a VIP of 192.168.10.10
but
I also need to terminate all inbound SSL connections for *.french.ca
which needs to use VIP 192.168.10.20
Right now all connections still appear to be going thru the 192.168.10.10 VIP when I look at service policy hitcounts.
Here is my config
class-map match-all english
   2 match virtual-address 192.168.10.10 255.255.255.224 tcp eq https
class-map match-all french
   2 match virtual-address 192.168.10.20 255.255.255.224 tcp eq https
policy-map multi-match vip
  class english
    loadbalance vip inservice
    loadbalance policy english
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 500
    ssl-proxy server english
  class french
    loadbalance policy french
    nat dynamic 2 vlan 500
    ssl-proxy server french
interface vlan 500
  description xxxxxxx
  ip address 192.168.10.2 255.255.255.224
  access-group input 101
  nat-pool 2 192.168.10.20 192.168.10.20 netmask 255.255.255.255 pat
  nat-pool 1 192.168.10.10 192.168.10.20 netmask 255.255.255.255 pat
  service-policy input vip
  service-policy input REMOTE_MGMT_ALLOW_POLICY
  no shutdown
Sh service-policy summary shows that no matter what...all ssl connections are hitting against the english vip
service-policy: vip
Class                                  VIP                                      Prot  Port        VLAN          State    Curr Conns   Hit Count  Conns Drop
english                             204.101.28.164                            tcp   eq 443      1,500         IN-SRVC           0          11          0
french                              204.101.28.166                            tcp   eq 443      1,500         IN-SRVC           0           0          0
Surely I must be able to run multiple VIPS ?
Cheers
Dave
Cesar Roque
Level 8
Level 8
Hello Dave,
Try changing the match statements, it should look like this:
   2 match virtual-address 192.168.10.10  tcp eq https
   2 match virtual-address 192.168.10.20  tcp eq https
Cesar R
--------------------- Cesar R ANS Team
Cesar Roque
Level 8
Level 8
Hello Dave,
Cesar R
So no need for the masks ?
Cheers
Dave
Hey Cesar, that seemed to fix my issue...I had gone with a work around and created a seperate context for the french connections which worked fine..but this way saves me from burning another public IP for int vlan 500 in the french context.
Thanks alot
Dave
ajayku2
when you use a mask you ideally end up taking the entire subnet in this case you used the range:
191.166.10.1 - 191.166.10.30  <<< 192.168.10.10 255.255.255.224 >>>>
Thats the reason for the trouble never use mask for the vip.
regards,
Ajay Kumar
