ACE 4710 with A5(1.1) with SSL termination
skamelsd
we  configued An ACE 4710  with SSL termination
on Oracle Aplication Server  10g  (10.1.2.0.2) ,so that SSL termination is done on the ACE and HTTP reaches the Oracle Aplication Server  10g  (10.1.2.0.2)
then we configure the ACE to enabled client authentication with Pkcs#11 smart card token certificate and this don succfully
my problem need do this client certificate authentication  for only the
https://www.mywebsite.com/admin/login.jsp page
not for all SSL proxy service how can do that.
Kanwaljeet Singh
Hi Sayed,
As you know client authentication is part of SSL handshake. The problem is that the server doesn't know if the client wants https://abc.com or https://abc.com/xyz until the SSL handshake has been completed.
I don't think there is any way to configure client authentication for a specific URL. There would be a SSL handshake again whenever server wants to authenticate the client.
Kanwal
Thanks Kanwal ,
i need a way to configure ACE 4710 with SSL Termination acts as microsoft IIS which can be configued for specific client certificate URL like https://abc.com/admin but the other https://abc.com/*   not required client certificate, this also we can do  it by Apache server.
Hi Sayed,
I don't think that is possible on ACE for reason told above.
Kanwa
