ACE and host static routes?
ciscocsoc
Level 4
Level 4
Does an ACE context work with host static routes?
I've been trying to set up a context to load balance LDAP where the servers have IP addresses across multiple VLANs and I'm not allowed to change the IP addresses. I've tried bridging and routing configurations. The only case that works is where the server is a member of the server-side VLAN. I noticed a comment in the Routing manual page 2-2 is says that secondary IP addresses are not supported. Is a host static route equivalent to a secondary address.
Is it possible to achieve my goal.
Thank you
Cathy
15 Replies 15
no particular concern when enabling ssl termination in regards to nat.
I'm glad we finally found a solution.
Gilles.
