ACE balance cookie + https
Rafael Mendes
Level 5
Level 5
Hello Everyone,
i have a ACE 4400 Appliance, for balance some applications on the network.
i have one application(citrix), the connection to this site is https(443).
I had a balance of cookie, plus this only worked if I left only one  server in "inservice" on Serverfarm if I add the second, the application  showed me a scree saying "your web interface session is in an  inconsistent state."
Since the above problems, I set the cookie for connection to work with "persistence rebalance," but the problem continued.
After I passed the Serverfarm to be balanced by source IP, the troubles are over, I kept the persistence rebalance.
Now comes the question, why not work with cookie? https does not work if the balancing change something in the package, such as information inside a cookie?
Old configuration:
sticky http-cookie NFUSE-COOKIE STICKY-HIAE-NFUSE-COOKIE
  cookie insert browser-expire
  replicate sticky
  serverfarm SF-HIAE-NFUSE
Current Configuration:
sticky ip-netmask 255.255.255.255 address source STICKY-HIAE-TESTE-NFUSE
  replicate sticky
Class/Policy and Parameter map.
class-map match-all VS-HIAE-NFUSE
   2 match virtual-address 192.168.16.30 tcp any
policy-map type loadbalance first-match VS-HIAE-NFUSE-l7slb
  class class-default
    sticky-serverfarm STICKY-HIAE-TESTE-NFUSE
  class VS-HIAE-NFUSE
    loadbalance vip inservice
    loadbalance policy VS-HIAE-NFUSE-l7slb
    loadbalance vip icmp-reply active primary-inservice
    appl-parameter http advanced-options HTTP-OPTS
parameter-map type http HTTP-OPTS
    persistence-rebalance
Tks a lot.
Rafael Mendes
Rafael,
You have 2 possibilities:
1- you terminate the SSL traffic on the ACE. In this case, the ACE will be able to read the cookie and apply stickiness correctly.
2- You use the SSL stickiness.
In the latter case, since the ACE is not doing SSL termination, thereforeyou need to match on the ssl payload, i.e.:
sticky layer4-payload STICKY-SSL
     serverfarm EXCHANGE2K10HUB_OWA1
     response sticky
     layer4-payload offset 43 length 32 begin-pattern "\x20"
You can find in this document quite nice examples about it:
http://docwiki.cisco.com/wiki/Secure_Sockets_Layer_Persistence_Configuration_Example
Cheers,Domenico.
6 Replies 6
ddastoli
Hi Rafael.
First thing to figure out here is:
are you terminating SSL on the ACE?
If not, ACE will not be able to read the https and eventually no cookie stickiness can be done.
In this case, you should use
Cheers,
Domenico
Hi Domenico,
I terminating ssl on the server, the serverfarm/rserver is configured for all ports.
Example:
rserver: Server1
   X.X.X.X:0
rserver: Server2
    X.X.X.X:0
This setting would only work if the direct Serverfarm was configured on port 443, is it?
Anyway, if I set up a balancing L4, would have no problems in changes in the package, you're right.
Can you give me an example configuration L4?
Tks..
Rafael,
     response sticky
Cheers,Domenico.
Ok Domenico.
Tks for the Help
Realized the configuration as specified in the link.
Apparently, everything ok.
However, I can not access the page using internet explorer. I tested with firefox, safari, opera, everything works with internet explorer not.
Configuration follows below, is something wrong?
Thanks.
serverfarm host SF-HIAE-NFUSE
  description Servidores nfuse.einstein.br
  rserver WPVAP06
    inservice
  rserver WPVAP07
    inservice
parameter-map type generic sslidparam
   set max-parse-length 70
sticky layer4-payload STICK-L4-NFUSE-SSL
  serverfarm SF-HIAE-TESTESSLTERM
  response sticky
class-map match-all VS-L4-NFUSE-SSL-TERMINATOR
  2 match virtual-address 192.168.16.254 tcp eq https
policy-map type loadbalance generic first-match VS-HIAE-TESTESSLTERM
  class class-default
    sticky-serverfarm STICK-L4-NFUSE-SSL
policy-map multi-match int10
class VS-L4-NFUSE-SSL-TERMINATOR
   loadbalance policy VS-HIAE-TESTESSLTERM
   appl-parameter generic advanced-options sslidparam
Rafael, can you try
layer4-payload offset 43 length 32 begin-pattern "(\x20|\x00\xST)"
If still does not work, check out those bugs and workaround, it may help:
CSCsh04655    GPP/TCP: Regex Parser hangs for .*keyword.* and .*keyword configs
CSCsx30496    sticky layer4-payload w/ small packets fail to LB
Cheers,
Domenico.
