ACE certificate issue
craig bache
I am having an issue with connecting to a server farm Internal-FARM. The issue is when trying to connect to it either with IP or DNS name Firefox gives the error below: I am able to ping the vip. The ACE is running in routed mode running SSL termination.
Unable to connect
Firefox can't establish a connection to the server at
* The site could be temporarily unavailable or too busy.
Internet explorer gives a similar error.
This had been working fine. The only changes made to the ACE modules is to generate a new key file and csr using the :
crypto generate key 2048 RSAKEY2048.PEM
crypto generate csr PARAMS-1 RSAKEY2048.PEM
------Current ssl-proxy ------ that was working.
ssl-proxy service proxy-Internal
  key key.pem
  cert tempcert1.pem
service-policy input loadbalance
policy-map multi-match loadbalance
class Internal-Classify
    loadbalance vip inservice
    loadbalance policy Internal-vip
    loadbalance vip icmp-reply
    ssl-proxy server proxy-Internal
policy-map type loadbalance first-match Internal-vip
  class class-default
    sticky-serverfarm SGROUP3
class-map match-any Internal-Classify
  3 match virtual-address x.x.x.x tcp eq https
sticky ip-netmask 255.255.255.255 address both SGROUP3
  timeout 61
  replicate sticky
  serverfarm Internal-FARM
The serverfarm and rservers are in service, but I can see the following on the show service-policy detail
class: Internal-Classify
      ssl-proxy server: proxy-Internal
     VIP Address:    Protocol:  Port:
     x.x.x.x   tcp        eq    443
      loadbalance:
        L7 loadbalance policy: Internal-vip
        VIP Route Metric     : 77
        VIP Route Advertise  : DISABLED
        VIP ICMP Reply       : ENABLED
        VIP State: INSERVICE
        curr conns       : 0         , hit count: 277 ---------------------------- Both counters are incrementing "hit count" and "dropped cons"
        dropped conns    : 113 -------------------------------------------------------------
        client pkt count : 5548      , client byte count: 659303
        server pkt count : 7866      , server byte count: 10409414
        conn-rate-limit      : 0         , drop-count : 0
        bandwidth-rate-limit : 0         , drop-count : 0
        L7 Loadbalance policy : Internal-vip
          class/match : class-default
             LB action: :
               sticky group: SGROUP3
                  primary serverfarm: Internal-FARM
                    state: UP
                  backup serverfarm : -
            hit count        : 174
            dropped conns    : 0
Regards Craig
Cesar Roque
Level 4
Level 4
Hello Craig,
Did you verify the cert and key match?  If not try with the command
# crypto verify key.pem tempcert1.pem
In addition, please copy  the serverfarm configuration
--------------------- Cesar R ANS Team
Thank you for the response, the key has passed the verify command. Please see the following output.
sh serverfarm Internal-FARM detail
serverfarm     : Internal-FARM, type: HOST
total rservers : 4
active rservers: 4
description    : -
state          : ACTIVE
predictor      : LEASTCONNS
   slowstart    : 0 secs
failaction     : -
back-inservice    : 0
partial-threshold : 0
num times failover       : 0
num times back inservice : 1
total conn-dropcount : 0
Probe(s) :
    http-probe,  type = HTTP
                                                ----------connections-----------
       real                  weight state        current    total      failures
   rserver: WEB01
       x.x.x.x:8881     8      OPERATIONAL  0          65         11
         description          : -
         max-conns            : -         , out-of-rotation count : -
         min-conns            : -
         conn-rate-limit      : -         , out-of-rotation count : -
         bandwidth-rate-limit : -         , out-of-rotation count : -
         retcode out-of-rotation count : -
         load value           : 0
   rserver: WEB02
       x.x.x.x:8881     8      OPERATIONAL  0          36         0
         description          : -
         min-conns            : -
         load value           : 0
   rserver: WEBLIVE1
       x.x.x.:8881     8      OPERATIONAL  0          48         8
         description          : -
         min-conns            : -
         load value           : 0
   rserver: WEBLIVE2
       x.x.x.x:8881     8      OPERATIONAL  0          6          0
         description          : -
         min-conns            : -
         load value           : 0
running config serverfarm
serverfarm host Internal-FARM
  predictor leastconns
  probe http-probe
  rserver WEB01 8881
    inservice
  rserver WEB02 8881
    inservice
  rserver WEBLIVE1 8881
    inservice
  rserver WEBLIVE2 8881
    inservice
Regards Craig
Hi Craig,
1) could remove the leastconns predictor?
2) could you take the SSLcapture from the client and check where the SSL phase complete correctly and who stops, in case the connection?
If you eventually get an TLS ALERT ERROR, decrypt the trace with the private key and see more in detail which error it is.
Alessandro
