ACE class-map match url syntax
adam.zinser
Frequent Visitor
Frequent Visitor
Can someone help me with the string that would match a url with no path specified?  For instance; user types "https://outlook.domain.net" into their browser and I want the ACE to redirect that request to https://outlook.domain.net/owa".
  2 match http url oulook\.domain\.net\
I set up a similar thing for our SAP portal - if the original request is just a '/' at the end with no path after.
class-map type http loadbalance match-any rootURL
  description **If the URL is root then redirect**
  2 match http url \x2F
Perhaps this is what you are after?
Cheers
Cameron
8 Replies 8
shday
Level 2
Level 2
I want to do something similar.
I want a class-map that will match http://domain.com so I can redirect those requests to a link page, but I want everything going to http://domain.com/any_path to be sent to a serverfarm.
I think the class-map would look something like this,
2 match http url domain\.com.*
3 match http url domain\.com\.
Am I even close.
Pablo
Adam and Shday,
I'll give you a hand on this 😃
Adam we can solve your problem only if you're doing SSL offloading on the ACE as the layer 5 information that needs to be checked is being sent encrypted.
In case SSL termination is configured then the configuration would be like this:
rserver redirect OWA
  webhost-redirection https://%h/owa 301
  inservice
serverfarm redirect OWA
  rserver OWA
    inservice
class-map type http loadbalance match-any OWA
2 match http header Host header-value "outlook.domain.net"
policy-map type loadbalance first-match OWA
class OWA
  serverfarm OWA
class class-default
  serverfarm Backend
Shday yours is pretty much the same but you need to decide if class-default needs
to be in place:
rserver redirect Domain
webhost-redirection http://%h/any_path 301
inservice
serverfarm redirect Domain
   rserver Domain
     inservice
class-map type http loadbalance match-any Any
2 match http url /.*
class-map type http loadbalance match-any Domain
2 match http header Host header-value "domain.com"
policy-map type loadbalance first-match Domain
class Any
  serverfarm Backend
class Domain
  serverfarm Domain
__ __
Pablo
I tried this class-map and policy.  I get to my backend server,
but I can't get anything to hit the redirect.  Everything is matching on the first class-map
I am using http://domain.com in my browser and my header class-map looks like this,
class-map match-any vip-of-domain
2 match virtual-address 206.201.79.20 tcp any
class-map type http loadbalance match-any any-url
2 match http url /.*   ---------------- doesn't this mean any url
class-map type http loadbalance match-any domain
2 match http header Host header-value domain.com
policy-map type loadbalance first-match domain-lbpl
class any-url
serverfarm backend-serverfarm
class domain
serverfarm domain-redirect
policy-map multi-match domain-mmpl
class vip-of-domain
loadbalance vip inservice
loadbalance policy domain-lbpl
I think its matching based on the /.* and never gets to the header class-map.
This causes an infinite loop.  I've run through several configurations that have this same flaw in them.  I need a configuration that explicitly specifies that the redirect should only happen when there are no characters in the path.  I attempted the url match with both \r and \n, also with no luck.
Adam, Shday,
My bad please try config below:
  inservice
  rserver OWA
    inservice
class-map type http loadbalance match-any Outlook
2 match http url /owa.*
class OWA
  serverfarm Backend
class Outlook
  serverfarm OWA
inservice
rserver Domain
  inservice
2 match http url http://domain.com/.*
class Any
  serverfarm Backend
class Domain
  serverfarm Domain
Regards.
__ __
Pablo
still doesn't work.
I put http://cranapple.farms.com and its redirected.  If i put http://cranapple.farms.com/florida I get redirected.
I only want to be redirected if I see http://cranapple.farms.com
Cheers
Cameron
Cameron:   TAC gave me "2 match http url /" but I went ahead and threw your match in as well to test.  Same results; both work.  Odd thing is that when I put in the root URL I get redirected to my OWA page.  If I then enter the root URL again into the same window, it takes me to the default IIS page.  I'm not too worried about it as I don't see this as a likely user encounter, but if you've got any thoughts on why that would happen....  Thanks for your help.
