ACE configuration - Return flow from WEB to WAS for SSO
Paul Pinto
Good day,
We have a requirement to provide load balancing of a return for SSO functionality. The flow requirement is is follows:
1. Client--->ACE client VLAN VIP----->WEB servers(serperate VLAN - routed mode)
2. Web servers--------->WAS servers on seperate VLAN (not load balanced by ACE- using IBM Webshere)
3. WAS servers----->ACE client VLAN VIP (same as 1. above)------>WEB Servers (same as 1. above. Seperate VLAN - routed mode)
So three VLAN's, Client VLAN, Web server VLAN and WAS server VLAN in same context. Point three is the return flow from WAS servers to Web servers for SSO.
Configuration applied is below. The question is would this configuration achieve what is required? Also to confirm, which interface the policy-map
WASSSO-VIP should be applied to, the WEB or WAS server VLAN?
access-list any line 1 extended permit icmp any any
access-list any line 2 extended permit ip any any
rserver host SZAWAS1
  ip address 10.250.203.139
  inservice
rserver host SZAWAS2
  ip address 10.250.203.140
  inservice
rserver host SZAWEB1
  ip address 10.250.202.171
  inservice
rserver host SZAWEB2
  ip address 10.250.202.172
  inservice
serverfarm host SZAFIN_WASFARM
  failaction purge
  predictor leastconns slowstart 60
  probe SZAWAS_TCP10001
  probe SZAWAS_TCP10002
  probe SZAWAS_TCP10003
  fail-on-all
  rserver SZAWAS1
    inservice
  rserver SZAWAS2
    inservice
serverfarm host SZAFIN_WAS_SSO_FARM
  failaction purge
  probe SZAWAS_SSO_TCP
  rserver SZAWAS1
    inservice
  rserver SZAWAS2
    inservice
serverfarm host SZAFIN_WEBFARM
  failaction purge
  probe SZAWEB_TCP
  rserver SZAWEB1
    inservice
  rserver SZAWEB2
    inservice
parameter-map type generic SSLID_PARAMMAP
  set max-parse-length 76
parameter-map type connection TCP_PARAM_MAP
  set timeout inactivity 1800
  set tcp timeout embryonic 900
  set tcp timeout half-closed 900
sticky layer4-payload SSL_WEB_GROUP
  timeout 15
  serverfarm SZAFIN_WEBFARM
  response sticky
  layer4-payload offset 43 length 32 begin-pattern "(\x20|\x00\xST)"
class-map match-any L4VIPCLASS_CB_FIN_WASSSO_SA_SIT
  2 match virtual-address 10.250.202.75 tcp eq https
class-map match-any L4VIPCLASS_CB_FIN_WAS_SA_SIT
  2 match virtual-address 10.250.202.75 tcp eq 10001
  3 match virtual-address 10.250.202.75 tcp eq 10002
  4 match virtual-address 10.250.202.75 tcp eq 10003
class-map match-all L4VIPCLASS_CB_FIN_WEB_SA_SIT
class-map type management match-any REMOTE_ACCESS
  2 match protocol ssh any
  3 match protocol telnet any
  4 match protocol icmp any
  5 match protocol snmp any
  6 match protocol http any
  7 match protocol https any
policy-map type management first-match REMOTE_MGMT_ALLOW_POLICY
  class REMOTE_ACCESS
    permit
policy-map type loadbalance first-match CB_FIN_WASSSO_SA_SIT
  class class-default
    serverfarm SZAFIN_WAS_SSO_FARM
policy-map type loadbalance first-match CB_FIN_WAS_SA_SIT
  class class-default
    serverfarm SZAFIN_WASFARM
policy-map type loadbalance generic first-match SSLID_32_WEB_POLICY
  class class-default
    sticky-serverfarm SSL_WEB_GROUP
policy-map multi-match CLIENT-VIPs
  class L4VIPCLASS_CB_FIN_WEB_SA_SIT
    loadbalance vip inservice
    loadbalance policy SSLID_32_WEB_POLICY
    loadbalance vip icmp-reply active
    loadbalance vip advertise active
    appl-parameter generic advanced-options SSLID_PARAMMAP
    connection advanced-options TCP_PARAM_MAP
  class L4VIPCLASS_CB_FIN_WAS_SA_SIT
    loadbalance policy CB_FIN_WAS_SA_SIT
policy-map multi-match WASSSO-VIP
  class L4VIPCLASS_CB_FIN_WASSSO_SA_SIT
    loadbalance policy CB_FIN_WASSSO_SA_SIT
interface vlan 303
  description WAS Server Vlan
  ip address 10.250.203.133 255.255.255.224
  alias 10.250.203.132 255.255.255.224
  peer ip address 10.250.203.134 255.255.255.224
  no normalization
  no icmp-guard
  access-group input any
  access-group output any
  no shutdown
interface vlan 306
  description Client Access Vlan
  ip address 10.250.202.69 255.255.255.192
  alias 10.250.202.68 255.255.255.192
  peer ip address 10.250.202.70 255.255.255.192
  no normalization
  no icmp-guard
  service-policy input CLIENT-VIPs
  no shutdown
interface vlan 308
  description WEB Server Vlan
  ip address 10.250.202.165 255.255.255.224
  alias 10.250.202.164 255.255.255.224
  peer ip address 10.250.202.166 255.255.255.224
  no normalization
  no icmp-guard
  no shutdown
ip route 0.0.0.0 0.0.0.0 10.250.202.65
Any advice would be greatly appreciated.
Thank you.
Paul
Paul Pinto
Good day,
Any feedback on this? I think the policy-map WASSSO-VIP should be on the WAS Server Vlan (303). Also with this implementation, Source NAT would not be required for the flow from the WAS servers back to the Web servers, correct?
Thank you.
Paul.
