Ace - connection reset (Error 101)
nicolasxy
Community Member
Hi, I have a problem with a Cisco ACE, after approximately an hour being in production, for all new connections
it gives the message: connection reset. The message on any web browser is: connection reset (Error 101)
It blocks any backend server (Apache).I get same error also when I try to connect direcly to the backend address.
This error saturates the connections on the servers (in the log of the DB I found error connection reset)
Without ACE all work fine, it's not a load traffic issue.
It seems like once opened a connection the ace does not close it anymore!
But the graphical snmp servers do not report the increase in connections, what is mistake ?
The balancer manages two physical servers and is configured in stickyness mode
Please find attached the configuration
logging enable
logging timestamp
logging trap 4
logging buffered 3
logging host 172.16.0.2 udp/514 format emblem
access-list ANY line 8 extended permit icmp any any
access-list ANY line 16 extended permit ip any any
probe http HTTP_PROBE1
  request method get url /index.php
  expect status 200 206
  expect status 300 307
  expect status 400 417
probe tcp PROBE_TCP
  interval 30
rserver host 03a.it
  ip address 172.16.0.1
  conn-limit max 50000 min 40000
  inservice
rserver host 03b.it
  ip address 172.16.0.2
  inservice
serverfarm host FARM_WEB
  predictor leastconns
probe HTTP_PROBE1
  rserver 03a.it
    inservice
  rserver 03b.it
    inservice
parameter-map type http HTTP_PARAMETER_MAP
  persistence-rebalance
sticky http-cookie session StickyGroup1
  timeout 3600
  serverfarm FARM_WEB
class-map type management match-all ICMP-ALLOW_CLASS
  2 match protocol icmp source-address x.x.x.x
class-map match-all L4-WEB-IP
  2 match virtual-address x.x.x.x tcp eq www
class-map type management match-all REMOTE_ACCESS
  2 match protocol ssh any
policy-map type management first-match REMOTE_MGMT_ALLOW_POLICY
  class REMOTE_ACCESS
    permit
policy-map type loadbalance http first-match WEB_L7_POLICY
  class class-default
    sticky-serverfarm StickyGroup1
    insert-http x-forward header-value "%is"
policy-map multi-match WEB-to-vIPs
  class L4-WEB-IP
    loadbalance vip inservice
    loadbalance policy WEB_L7_POLICY
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 2541
    appl-parameter http advanced-options HTTP_PARAMETER_MAP
interface vlan 125
  ip address
  access-group input ANY
  service-policy input REMOTE_MGMT_ALLOW_POLICY
  service-policy input WEB-to-vIPs
  no shutdown
interface vlan 254
  ip address
  nat-pool
  no shutdown
At the moment this happens, the simultaneous connections (command: show conn) on the server are around 350
the CPU load is 2%
sticky database has approximately 24000 records.
Log level is set to 4. But no error report.
Do you need more info to resolve the problem?
Thank you
Best Regards
N.
Jorge Bejarano
Level 10
Level 10
Hello Nicolas,
Can you upload these files zipped?
#show serverfarm FARM_WEB
#show serverfarm FARM_WEB detail
#show stats http
#show stats loadbalance
#show resource usage all
#show service-policy WEB-to-vIPs class-map L4-WEB-IP
#show probe HTTP_PROBE1
#show probe HTTP_PROBE1 detail
Jorge
Please find attached the output of commands you request.
They have been executed a few hours after the problem occurred.
I hope you find them useful
Do you need any others ?
Many Thanks
Hello Nicolas,
I wonder if you can include these values:
  case-insensitive
  set header-maxparse-length 65535
  set content-maxparse-length 65535
  length-exceed continue
  parsing non-strict
I also noticed a lot of errors which might be caused also due to these denied under the #show resource usage all which may indicate you are reaching the license limits, but you should discuss it with your Cisco SE, please see below:
                                               Allocation
        Resource         Current       Peak        Min        Max       Denied
Context: vrack254
  conc-connections              4       1267      60000      60000          0
  mgmt-connections              2         28        748        748          0
  proxy-connections             0       1255       7864       7864          0
  xlates                        0          0       7864       7864          0
  bandwidth                   572    3824781    3740624  127490624    1416859
    throughput                 96    3712886    3740624    3740624    1416859
    mgmt-traffic rate         476     111895          0  123750000          0
  connection rate               1       1729       4500       4500          0
  ssl-connections rate          0          0        224        224          0
  mac-miss rate                 0         15         16         16          4
  inspect-conn rate             0          0       1800       1800          0
  http-comp rate                0          0    5898240    5898240          0
  to-cp-ipcp rate               0         11         36         36          0
  acl-memory                 8216      10568     744800     744800          0
  sticky                    22978      22978      31456      31456          0
  regexp                       19         23       7864       7864          0
  syslog buffer             30720      30720      30720      30720          0
  syslog rate                   0          6        750        750          0
Can you upload the specific error which you are getting also?
Jorge
     my "Cisco SE" says my bandwitch limit is 30Mbps.
In my snmp data from cisco ace, I see that the total traffic on the balancer is:
  1,708MB/s(13,664Mbps)
- IN: 1,55MB/s (12,4Mbps)
- OUT: 158kB/s (1,264Mbps)
I do not understand which is the  unit of measure of the command "show resource usage all"
                                                Allocation
Can you tell me if they are byte? So I can understand the values from "Denied" and "Max"
Last question: How can I undestand if I reached the 30Mbps limit ?
Many Thanks
Nicolas
