ACE: console Roll over, cross over, standard 232 cable
s.srivas
I'm trying to access the ACE via console port and it does not seem to respond. What type of cable should I be using.
Please explain the differences and how to check if i have the correct cable.
(Not: During fault tolerance configs, password apear to be mixed up and I'm not able to access via session, login incorrect.)
SS
ciscocsoc
Level 4
Level 4
From the Administration Guide, Pages 1-1 and 1-2:
"You can establish a direct serial connection between your terminal and the ACE by making a serial connection to the console port on the front of the ACE. The console port is an asynchronous RS-232 serial port with an RJ-45 connector. Any device connected to this port must be capable of asynchronous transmission. Connection requires a terminal configured as 9600 baud, 8 data bits, 1 stop bit, no parity."
You need to connect this to a serial port on your PC/laptop. One of the standard blue Cisco console cables will do the trick.
Cathy
ciscocsoc
Level 4
Level 4
Cathy
Cathy,
I can login to switch console port
using the same cable, same setup
setup to 9600,8,1,none I could not connect to ACE console.
I have a suspision that the RS232 etc means this is not that blue, flat cable!
Oh
using the normal cisco cable, but setting flow control off and it works now.
Thanks Cathy.
