ACE context management
craig bache
Level 4
Level 4
I am looking at management (backup of the configuration) of the ACE 4710 running A4.1, the management software is Cisco Cirrus. The question I have is around the management of the context's, I have a backup of the Admin but would like the user context's also, does anyone know how this is completed.
Regards Craig
ajayku2
Hi Craig,
You can login to ACE and run :
backup [all][pass-phrase
host1/Admin# backup all pass-phrase
backup all
—(Optional)  Specifies that the ACE should back up the configuration files and  dependencies in all contexts. You can specify this keyword only in the  Admin context.
RUN
show backup status to check the status of backup
Hope that helps.
regards,
Ajay Kumar
Hi Ajay
Thanks, so this has to be a manual process from the ACE. The Admin context configuration has been obtained via snmp.
Regards Craig
Hi Craig,
I dont have any idea how to do with Cisco Cirrus software. manual process is easy. Create a backup and then copy it to some ftp server.
regards,
Ajay Kumar.
