ACE Design
I'm don't have many experience with Cisco ACE and I'd like to know if it's possible to have the clients and the servers located at the same VLAN (192.168.0.0/24). The clients will make the http request to a VIP address (10.0.0.10/24) and the ACE should redirect the request to the rservers located in the same VLAN.
Thanks in advance.
rodrguti_2
Hi Fernando,
To answer your question, yes, you can have clients and servers located in the same vlan, you will need to use a natpool here in order to avoid asymmetric flows, here you can find a couple of configuration examples which are very useful:
http://docwiki.cisco.com/wiki/Category:Data_Center_Application_Services_Configuration_Examples
Saludos,
Rodrigo
Hi Rodrigo,
Thank you very much for your answer. I'll check the examples.
Kind regards,
Fernando
