ACE DNS issue
mj11
Level 6
Level 6
Hi All
I have come across a problem with our ACE service modules. This is performing DNS load balancing with our servers, which is working fine, with the exception of the following order of events;
The client tries two queries in quick succession for A and AAAA records, the ACE is closing the SLB session the instant a DNS answer comes back. This is causing problems with clients that make 2 lookups very quickly, from the same source port.
The ACE module is running A2(2.4).
Any help much appiracted.
Regards MJ
cpomeroy
Level 4
Level 4
MJ,
   Are you using DNS inspection?
Chris
Hi Chris
Thanks for the response, yes DNS inspection is in use.
Regards MJ
MJ,
   If this is a non-production environment, I would try to turn on DNS inspect.  DNS inspect checks to ensure there is only one DNS request per connection.  If the second request is hitting the ACE prior to a response for the first then the second request will be dropped.  If it works without DNS inspect enabled, I would ask that you open a TAC case so we can gather addtional data.  In the meantime you can see DNS inspect errors with the following commands:
sh np 1 me-stats "-sfixup -v"
sh np 2 me-stats "-sfixup -v"
Chris
Hi Chris
Thanks for the update, I have tried with DNS inspection disabled but this is still the case.
Regards MJ
