ACE DNS issue
mj11
Level 3
Level 3
Hi All
I have come across a problem with our ACE service modules. This is performing DNS load balancing with our servers, which is working fine, with the exception of the following order of events;
The client tries two queries in quick succession for A and AAAA records, the ACE is closing the SLB session the instant a DNS answer comes back. This is causing problems with clients that make 2 lookups very quickly, from the same source port.
The ACE module is running A2(2.4).
Any help much appiracted.
Regards MJ
cpomeroy
MJ,
   Are you using DNS inspection?
Chris
Hi Chris
Thanks for the response, yes DNS inspection is in use.
Regards MJ
MJ,
   If this is a non-production environment, I would try to turn on DNS inspect.  DNS inspect checks to ensure there is only one DNS request per connection.  If the second request is hitting the ACE prior to a response for the first then the second request will be dropped.  If it works without DNS inspect enabled, I would ask that you open a TAC case so we can gather addtional data.  In the meantime you can see DNS inspect errors with the following commands:
sh np 1 me-stats "-sfixup -v"
sh np 2 me-stats "-sfixup -v"
Chris
Hi Chris
Thanks for the update, I have tried with DNS inspection disabled but this is still the case.
Regards MJ
