ACE eliminate insertion of http-header in some case
Alex Labuta
Hi All!
I have already configure loadbalance for http proxy servers (squid with NTLM) on ACE
with NAT and http header-insertion
If browser send clear request without username and password all done, i see client ip source into x-forward header.
Else nothing insert.
All recommendation from forum and guides applyed  and over.
ACE2/proxy# show parameter-map HTTP_PARAMETER_MAP
Parameter-map : HTTP_PARAMETER_MAP
Description : -
Type : http
    server-side connection reuse       : disabled
    case-insensitive parsing           : enabled
    persistence-rebalance              : enabled
    inspect non-persistence            : enabled
    header modify per-request          : enabled
    parsing non-strict                 : enabled
    header-maxparse-length             : 16384
    content-maxparse-length            : 32768
    parse length-exceed action         : continue
    urlcookie-delimiters               : /&#+
    urlcookie-start                    : ?
What I do wrong?
I have ACE20 with 2.3.5 software
Daniel Arrondo Ostiz
Hi Alex,
I would suggest you to do a SPAN session of the internal TenGig interface connecting the ACE with the switch backplane. Seeing the differences between the working and failing scenarios will probably give you some hints on why the header insertion is not working.
If you need help to analyze the traffic capture, you can always open a TAC case
Daniel
Hi Daniel,
I am already have sniffers at client and serverside, it's insufficiently?
Best regard, Alex.
Hi Alex,
It's always better to get the captures on the backplane to really see what the ACE is sending/receiving (including the vlan tags), but having captures on the client and server may also be enough.
Daniel
