ACE - FQDN in a class map or other suggestions
robrothberg
It appears it is only possible to use an IP address when creating match conditions in a class map which makes sense.
We are using this basically as a NAT.
ie, server sends an HTTP message to the ACE containing XML
ACE then encrypts with an SSL cert and substitutes a public IP address and sends the XML out to a customer IP on the public internet
Problem is when customer changes the IP address, we need to change the configuration on the ACE.  Ideally if I could use a DNS name, then the customer can manage any changes via DNS and not involve us.
Disclaimer: I'm a complete novice to the ACE
Any ideas appreciated!
Kanwaljeet Singh
Hi Rob,
Can you share the current configuration and also the traffic flow here.
Kanwal
