ACE FT multi-context bridged VLANs
David Niemann
Level 3
Level 3
I have two ACE30 modules in 6509 VSS.  Each one will have three contexts (default Admin, DMZ and INSIDE).  I have created VLAN 100 and 110 for the bridged VLANs in the DMZ context and 200 and 210 for the bridged VLANs on the INSIDE context.  I want to configure failover and am trying to figure out the appropriate configuration.  The documentation discusses this in a single context with either bridging or routing.  I have additionally created a VLAN 135 that is to be used for the FT link. Do I configure the peer and group information on the Admin context or the individual context and do I only monitor the BVI interface or the actual VLANs themselves? I want to use Active/Active with DMZ primary being on peer1 and the INSIDE primary being on peer2.
I have the config below in the Admin context
ft interface vlan 153
  ip address 172.30.0.137 255.255.255.252
  peer ip address 172.30.0.138 255.255.255.252
context DMZ
  allocate-interface vlan 100
  allocate-interface vlan 110
  member 15-plus
context INSIDE
  allocate-interface vlan 200
  allocate-interface vlan 210
  member 15-plus
On the DMZ context I have this
interface vlan 100
  bridge-group 1
  access-group input BPDU
  access-group input ANYONE
interface vlan 110
  bridge-group 1
interface bvi 1
  ip address 172.31.0.147 255.255.255.0
  alias 172.31.0.149 255.255.255.0
ajayku2
Do I configure the peer and group information on the Admin context or the individual context ?
The FT is always configured in the Admin context.
You can monitor the vlan towards gateway.
Below is a document which explains it well :
http://docwiki.cisco.com/wiki/Cisco_Application_Control_Engine_%28ACE%29_Configuration_Examples_--_Administrative_Configuration_Examples
Config extracted from above link :
ft interface vlan 200
  peer ip address 192.168.1.2 255.255.255.0
  no shutdown
ft peer 1
  ft-interface vlan 200
  heartbeat interval 300
  heartbeat count 10
  query-interface vlan 100
ft group 1
  peer 1
  priority 200
  associate-context testcontext   <<<< You always associate the context >>>>>>
  inservice
ft track interface TRACK_VLAN100
  track-interface vlan 100
  peer track-interface vlan 200
  priority 50
  peer priority 5
Hope that helps.
regards,
Ajay Kumar
regards,
Ajay Kumar
ajayku2
  no shutdown
ft peer 1
  heartbeat count 10
ft group 1
  peer 1
  priority 200
  inservice
  priority 50
  peer priority 5
Hope that helps.
regards,
Ajay Kumar
regards,
Ajay Kumar
