ACE Health probe using get URL
Darren Sasso
We are trying to create a health probe for our google search appliances and as part of the URL get there is a question mark but the ACE doesn't like that.  Is there a way around this or should it be done differently?
request method get url /searchq? (This is what we want the URL to be)
request method get url /searchq (This is where it thinks i'm asking it for help)
Thanks in Advance.
Sean Merrow
Level 4
Level 4
You need to typ CRTL+v prior to entering the ?
That's the Control key then lowercase v, then your question mark.
Hope this helps,
Sean
Sean Merrow
Level 4
Level 4
Hope this helps,
Sean
That worked thanks a million!
