ACE HTTPS Termination
oriel_rose
Community Member
Hi Guys
First of all i am bit new to the ACE so apologies if i am being too silly.
Basically i have around 10 URLs. What load ACE 4710 is doing its just forwarding everything to couple of servers. What we want is basically all requests which will come as https:// , will have their certificate terminated on ACE and will be forwarded as HTTP to the servers.
Here is my current config.
rserver host server1
ip address 192.168.152
inservice
rserver host server2
ip address 192.168.1.154
inservice
class-map match-all https
11 match virtual-address 172.168.132.1 tcp eq 443
policy-map type loadbalance first-match https
class class-default
   serverfarm servers
nat dynamic 200 vlan 200 servers primary
policy-map multi-match policy
class https
   loadbalance vip inservice
   loadbalance policy loadbalance
   loadbalance vip icmp-reply
jbartoldus
Community Member
Here is your basic checklist to accomplish what you seek.
1.  Load the certs and keys on the ACE.  Reference the crypto CLI command
2.  Add serverfarm host which references the real servers.  Use port 80 when defining the real servers in the serverfarm
3.  Add ssl-proxy command to define SSL endpoint.  You will reference the appropriate cert/keys here
4.  Add ssl-proxy command to your class statement in the multi-match policy-map
Good luck!
Cesar Roque
Level 8
Level 8
Hi Oriel,
Here is a basic SSL configuration:
rserver host test
  ip address 10.198.16.98
  inservice
rserver host test2
  ip address 10.198.16.93
  inservice
serverfarm host test
  rserver test 80
    inservice
  rserver test2 80
    inservice
ssl-proxy service TEST
  key cert
  cert cert
class-map match-all VIPSSL
  2 match virtual-address 10.198.16.122 tcp eq https
policy-map type loadbalance first-match test
  class class-default
    serverfarm test
policy-map multi-match clients
  class VIPSSL
    loadbalance policy test
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 112
    ssl-proxy server TEST
interface vlan 112
  ip address 10.198.16.91 255.255.255.192
  access-group input Allow_Access
  nat-pool 1 10.198.16.122 10.198.16.122 netmask 255.255.255.192 pat
  service-policy input NSS_MGMT
  service-policy input clients
  no shutdown
ip route 0.0.0.0 0.0.0.0 10.198.16.65
Cesar R
ANS Team
--------------------- Cesar R ANS Team
