ACE in Direct Server Return mode not working as expected
Dear all,
I configured my ACE as I found it here:
https://supportforums.cisco.com/docs/DOC-22555
the VIP is working, that means I can ping it, routing is working etc.
I created a loopback on the win2012 Server with the IP of the VIP. When I try now to test the LB with telnet on port 25 e.g. it is not working. direclty on the server it works, also in my last deployment where I use SNAT/PAT. But we want the real client IPs visible on the Exchange Server.
Where is my problem ? Any ideas would be great..
rserver host YY
  description AServer-1
  ip address 10.1.x.2
  inservice
rserver host XX
  description AServer-2
  ip address 10.1.x.3
   inservice
serverfarm host Mail
  description Mail
  transparent
  predictor leastconns
  rserver AServer-1
    inservice
  rserver AServer-2
sticky ip-netmask 255.255.255.255 address both Mail
  timeout 5
  replicate sticky
  serverfarm Mail
class-map match-all Exchange_ALL
  2 match virtual-address 192.168.1.1 any
class-map type management match-any remote_access
  2 match protocol xml-https source-address 10.a.b.0 255.255.255.0
  3 match protocol icmp source-address 10.a.b.0 255.255.255.0
  5 match protocol ssh source-address 10.a.b.0 255.255.255.0
  7 match protocol https source-address 10.a.b.0 255.255.255.0
  8 match protocol snmp source-address 10.a.b.0 255.255.255.0
  9 match protocol xml-https source-address 10.d.e.1 255.255.255.255
  10 match protocol icmp source-address 10.d.e.1 255.255.255.255
  11 match protocol ssh source-address 10.d.e.1 255.255.255.255
  12 match protocol https source-address 10.d.e.1 255.255.255.255
  13 match protocol snmp source-address 10.d.e.1 255.255.255.255
policy-map type management first-match remote_mgmt_allow_policy
  class remote_access
    permit
policy-map type loadbalance first-match mail
  class class-default
    sticky-serverfarm Mail
policy-map multi-match VLAN20
  class Exchange_ALL
    loadbalance vip inservice
    loadbalance policy mail
    loadbalance vip icmp-reply
interface vlan 2
  ip address 10.a.b.2 255.255.255.0
  access-group input ALL
  service-policy input remote_mgmt_allow_policy
  no shutdown
interface vlan 20
  description Server
  ip address 10.1.x.20 255.255.255.0
  peer ip address 10.1.x.30 255.255.255.0
  no normalization
  service-policy input VLAN20
  no shutdown
ft interface vlan 4
  ip address 10.f.g.2 255.255.255.252
  peer ip address 10.f.g.1 255.255.255.252
  no shutdown
ft peer 1
  heartbeat interval 300
  heartbeat count 10
  ft-interface vlan 4
ft group 1
  peer 1
  associate-context Admin
  inservice
ip route 10.d.e.0 255.255.255.255 10.1.x.1
ip route 0.0.0.0 0.0.0.0 10.a.b.1
19 Replies 19
Hello, this is interesting.
What do you see on netstat when you establish a successful connection? The TCP handshake goes like this - im sure you know it already:
  1. client sends SYN to server
  2. server receives the SYN
  3. server sends SYN-ACK to client
  4. client receives SYN-ACK
  5. client sends ACK to server
  6. Server receives ACK
  7. Connection gets established
From the State:SYN_RECEIVED it seems as though we are stuck on number 2. This is on the server side. Seems as though the server is not responding back if its just stuck in this state.
Did you manage to have a look at my previoius post about the nic settings on the server - maybe its something your server team can look at?
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Yes as I mentioned, I did the change without success.
I have no idea at the moment but now access to the server. Maybe tomorrow I got a new idea. It's a hard nut in the moment.
It do u have another setup which makes sure the server will see the native client IP?
OK, I stopped wasting my time on that Design and found another, this seems to work.
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_configuration_example09186a00809c6ef5.shtml
As soon as I finished all my tests I will reply to u. This is just to stop for thinik about a enviroment what has changed ..
Yeha it works this way..thanks againg for your great help..Cu
Hey that's great news! Glad you found the solution. :-)
