ACE isn't load balancing as expected
gavin han
I've issue with two servers being load balanced on ACE. traffice isn't distributed equally:
probe tcp ProbePort80
  port 80
  interval 15
  passdetect interval 60
  open 1
rserver host Server1
  ip address 10.10.10.1
  probe ProbePort80
  inservice
rserver host Server2
  ip address 10.10.10.2
  probe ProbePort80
  inservice
serverfarm host Server-1-2-Loadbalanced
  failaction purge
  rserver Server1
    inservice
  rserver Server2
    inservice
sticky ip-netmask 255.255.255.128 address both Server-1-2-Loadbalanced
  timeout 60
  timeout activeconns
  replicate sticky
  serverfarm Server-1-2-Loadbalanced
class-map match-any Server-1-2-Loadbalanced
  2 match virtual-address 192.168.1.150 tcp any
policy-map type loadbalance first-match Server-1-2-Loadbalanced
  class class-default
    sticky-serverfarm Server-1-2-Loadbalanced
policy-map multi-match Load_Balanced_Vlan9
  class Server-1-2-Loadbalanced
    loadbalance vip inservice
    loadbalance policy Server-1-2-Loadbalanced
    loadbalance vip icmp-reply
ACE# sh serverf Server-1-2-Loadbalanced
serverfarm     : Server-1-2-Loadbalanced, type: HOST
total rservers : 2
                                                ----------connections-----------
       real                  weight state        current    total      failures
   rserver: Server1
       10.10.10.1:0      8      OPERATIONAL  134        387553153  76428027
   rserver: Server1
       10.10.10.2:0      8      OPERATIONAL  3270       192367801  32921205
as you can see above. 1st server got only 134 connections while 2nd server got 3270.
could help please.
pablo.nxh
Level 3
Level 3
Hi Gavin,
You may need to change the sticky netmask from /25 to /32 as shown in your output all the traffic from a single subnet is being stuck to the same real server.
sticky ip-netmask 255.255.255.255 address source Server-1-2-Loadbalanced
__ __
Pablo
Hi, thanks for your reply. could you advise the best practice to use stick netmask? how do we know what sticky netmask to use?
thanks.
Hi.
It depends on the requirements of your environment : using a /32 mask will provide better LB granularity (each incoming IP address will be load balanced as a new entity) but it will take a stick entry in the table for each client ip address.
Using larger masks, you'll lose LB granularity (LB will not be done per ip address but per network instead) but you'll save space into the sticky table, keeping it very small with large masks.
