ACE isssue for rserver with multiple IP on the same NIC
Dear all,
I'm doing to configure an ACE with bridged mode to load balance incoming traffic to 3 TMG servers following this network diagram:
The system design require to have 4 IP address on the same NIC, and 3 VIP for each pool of the IP as presented in the diagram (rserver: 172.22.14.52 & 62 & 72 - VIP: 172.22.14.82). The attached configuration of the ACE was tested successfully, but we discover that some NIC crash after a non-specific period (Server cannot ping their default gateway: Destination unreachable). I need then to restart the server to get things going well.
After troubleshooting many things, I discover that when I remove the service policy on the ACE interface, the problem disappears and server continue to work correctly.
Is it possible that this problem is due to having on the ACE arp table 3 IP address having the same mac? and how I can solve it?
Thanks, Abdelaziz
6 Replies 6
This is for help the show arp result. I see that the four IP address of each server have the same mac address but only the first IP is LEARNED. Is it normal?
IP ADDRESS      MAC-ADDRESS        Interface  Type      Encap  NextArp(s) Status
172.22.14.51    00.c0.dd.16.90.4c  vlan2014  LEARNED    15067  13964 sec    up
172.22.14.52    00.c0.dd.16.90.4c  vlan2014  RSERVER    15051  173 sec      up
172.22.14.53    00.c0.dd.16.90.4c  vlan2014  RSERVER    15057  177 sec      up
172.22.14.54    00.c0.dd.16.90.4c  vlan2014  RSERVER    15059  178 sec      up
172.22.14.61    00.c0.dd.16.ae.60  vlan2014  LEARNED    15058  13677 sec    up
172.22.14.62    00.c0.dd.16.ae.60  vlan2014  RSERVER    15050  172 sec      up
172.22.14.63    00.c0.dd.16.ae.60  vlan2014  RSERVER    15064  181 sec      up
172.22.14.64    00.c0.dd.16.ae.60  vlan2014  RSERVER    15061  179 sec      up
172.22.14.71    00.c0.dd.16.93.b8  vlan2014  LEARNED    15065  13700 sec    up
172.22.14.72    00.c0.dd.16.93.b8  vlan2014  RSERVER    15048  171 sec      up
172.22.14.73    00.c0.dd.16.93.b8  vlan2014  RSERVER    15062  179 sec      up
172.22.14.74    00.c0.dd.16.93.b8  vlan2014  RSERVER    15068  291 sec      up
172.22.14.253   88.43.e1.75.9a.80  vlan2024  LEARNED    15019  9328 sec     up
172.22.14.254   88.43.e1.75.96.00  vlan2024  GATEWAY    14463  36 sec       up
172.22.14.250   00.23.5e.26.1e.71  bvi3      INTERFACE  LOCAL     _         up
Well, my question is very simple, it seems for sure that having 3 rserver having the same mac address is causing a problem with ACE on bridged mode and blocking the traffic betweend the server and the firewall.
Is there any solution for that?
Thanks.
Hi Adelaziz,
As far as the ACE is concerned, there is no problem in having servers with multiple IP addresses. They will just be treated as separate reals.
From what you described, it seems that the fact that the server is receiving load-balancing connections may be leading to the issue, but bear in mind that the issue is on the server itself. Therefore, before trying to find a solution, you first need to understand what is causing the interface to fail. Then, if it's confirmed to be something related to the way the ACE handles connections, we can try to find a solution.
Regarding your question about the ARP table, the first IP address of each server is appearing as "Learned" indicating that it doesn't belong to either a real server or a gateway. This behavior is normal taking into account that those addresses are not associated to any real on the ACE.
Daniel
Hi Daniel,
I have 52 server working correctly and the only problem that I have is with these 3 server. I wanna ask if there is any problem to have rserver having the same mac address when we are using ACE in bridged mode?
Just for you information, when I remove the ACE, and having the traffic going directly to the firewall module, the problem disappear.
Regards, Abdelaziz
No, as I said, there is not problem from the ACE point of view.
hey dude, can you share pcaps files from the rsevers? I'll would like se how tcp sessions are stablished.
one cuestion,, this issue occurs inmediatly or it takes some time?
thanks.
the-great-l0k1
mx
