ACE Issue.
ajay chauhan
Level 11
Level 11
I would like to know about this config why its required and how it will work. if I remove class SOURCE_NAT how it will impact.
does that mean source-nat will only check class source-nat frist then next ?
policy-map multi-match SOURCE_NAT_POLICY
  class SOURCE_NAT
    nat dynamic 3 vlan 1201
policy-map multi-match vip-policy
  class prod-ad
    loadbalance vip inservice
    loadbalance policy prod-ad-policy
    loadbalance vip icmp-reply active primary-inservice
Ajay
10 Replies 10
pablo.nxh
Level 8
Level 8
Hi Ajay,
It depends where the SOURCE_NAT_POLICY is being applied, you can get really granular with ACE NAT options, it could be for server to VIP traffic, server to outside initiated conns etc. It's all about what's being matched with the class SOURCE_NAT and where the multi-match policy is implemented.
__ __
Pablo
Thanks Pablo.
I have one more issue here on switch ACE module is there.
I have a user vlan on switch and one management vlan/ vip vlan /server vlan associated with ACE.
when VIP is access via firewall for remote users it works and when used by this user group which is sitting on same switch
it comes like connection refused.
The only thing I have seen this traffic is routed over management vlan means SVI is on switch for management vlan also one ip is configured on ACE for managemnet .
The static route is pointing to management IP on ACE for VIP subnet from switch.
Just wanted to confirm if routing over management vlan does work .
Using same routing i can telnet on servers successfully not sure if we can use the same routing for VIPs as well.
Ajay
Hello Ajay,
Sounds  to me you're running into an asymmetric routing issue... Can you share a  sanited copy of your configuration so I can take a quick look?
__ __
Pablo
Hi Pablo,
Here is the config-
ON LB
interface vlan 1100
  description to ASA
  ip address 10.222.133.250 255.255.255.248
  alias 10.222.133.249 255.255.255.248
  peer ip address 10.222.133.251 255.255.255.248
  ip address 10.222.159.1 255.255.255.0 secondary
  peer ip address 10.222.159.2 255.255.255.0 secondary
  mac-address autogenerate
  access-group input TRAFFIC
  service-policy input vip
  no shutdown
interface vlan 1205
  description SERVERS
  ip address 10.222.163.4 255.255.255.0
  ip dhcp relay server 10.222.163.57
  ip dhcp relay enable
  alias 10.222.163.1 255.255.255.0
  peer ip address 10.222.163.5 255.255.255.0
  access-group output TRAFFIC
  nat-pool 4 10.222.163.253 10.222.163.253 netmask 255.255.255.0 pat
  no shutdown
interface vlan 1105
  description to MG
  ip address 10.222.129.18 255.255.255.0
  alias 10.222.129.21 255.255.255.0
  peer ip address 10.222.129.19 255.255.255.0
  no shutdown
ip route 10.222.128.0 255.255.128.0 10.224.129.1  < .1 is SVI on switch.
On switch
ip route 10.222.159.0 255.255.255.0 10.222.129.21
Hi Ajay,
Can you tell me the IP address of the client(s) that is getting connection refused? I think it is within the same server subnet 10.222.163.0/24 but I want to make sure.
__ __
Pablo
Hi Pablo,
I have multiple VLANs in range of 10.222.128.0 255.255.128.0 on switch and no success from any of the vlan for exmple
10.222.203.0/24.
Ajay
Oh in that case can you attach the ful show run of your ACE?
__ __
Pablo
Hi Pablo,
I am just wondering if the problem is to get into LB from management interface which has not got any service policy applied
on it.
Creating another SVI on switch and giving a IP address from VIP range can that solve my issue?
Ajay
Hi Ajay,
That's the problem at this point I don't know to which SVI your VIP belongs to; I see the service policy applied under both "traffic" interfaces; I guess it is on VLAN 1100 as it is working for remote users but that's what I wanted to confirm with the show run.
Does VLAN 1100 has a SVI created on the switch?
__ __
Pablo
Applying VIP policy on Management interface resolved the issue.
