ACE Load Balance setup and testing - vip
mbroberson1
Level 3
Level 3
Got a new ACE 4710 and am I new to the appliance. I am testing out a senario with load balancing between two servers. In testing when I ping the VIP ip address the replies I see are from the real server ip addresses. I am just wondering if this is the correct normal behavior or should I see the ping replies coming from the VIP ip address?
Peter Koltl
Level 7
Level 7
Do you use the
    loadbalance vip icmp-reply active
command?
policy-map multi-match POL45
  class VStest
    loadbalance vip inservice
    loadbalance policy L7SLBPOLtest
Hi Peter,
No I am currently not using the "loadbalance vip icmp-reply active" command. Not using this command is the result I am getting as expected?
