ACE load balancing based on URL
ehgotz
Community Member
I am trying to send traffic to one server or another based on the URL. I want traffic to foo.com/selfserv to direct to server A and traffic to foo.com/webui to direct to server B. I found URL inspection etc but I am not sure how to apply it the scenario as I do not want the ACE to inspect all inbound HTTP requests.
6 Replies 6
jbayuka
Level 9
Level 9
The ACE performs regular expression matching against the received packet data from a particular connection based on the HTTP URL string. To configure a class map to make Layer 7 SLB decisions based on the URL name and, optionally, the HTTP method, use the match http url command in class-map HTTP load balance configuration mode.
The ACE performs regular expression matching against the received packet data from a particular connection based on the RTSP URL string. You can configure a class map to make Layer 7 SLB decisions based on the URL name and optionally, the RTSP method, by using the match rtsp url command in class-map RTSP load balance configuration mode.
Configuring Traffic Policies for Server Load Balancing:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA3_1_0/configuration/slb/guide/classlb.html
I am also searching for a balance method based on some url parameters.
the answer of jbayuka sounds fine, but it doesn't really match the implemented url stickyness on CCS
On the CSS i configure it like:
owner test.de
content url_sticky
advanced-balance url
url "/*"
string prefix "shopId="
string eos-char "_"
so how can I configure the url stickyness from CSS on an ACE device ?
JeramyKoval
Level 2
Level 2
I'm sure someone will correct me if I'm wrong. 🙂 I am still trying to get my head around the ACE but I believe you can do this by setting up similar to this.
class-map type http loadbalance match-all FOO_A
10 match http header Host header-value foo.com
20 match http url /selfserv*
You would then apply the class-map to your policy-map and define serverfarm A.
Then basically duplicate this for /webui but configure that for serverfarm B.
class-map type http loadbalance match-all FOO_B
20 match http url /webui*
you are rigth, but in this solution you have to configure ONE Serverfarm for EACH service.
in css solution you configure one serverfarm with all server/services.
config on css look like:
owner test.de
content url_sticky
url "/*"
string eos-char "_"
add service1
add service2
add service3
service service1
ip address 1.1.1.1
string service1
service service2
ip address 1.1.1.2
string service1
service service3
ip address 1.1.1.3
string service3
due to the url stickyness config
all packets will send to server 1 if in the url appears "shopId=server1_", based in the string configuration,
all packets will send to server 2 if in the url appears "shopId=server2_" and so on.
So it looks like different implementation on CSS and ACE
I found the correct solution.
the goal is using "http-header" stickyness.
In the http-header you find the "GET" statemant followed by the url.
now you can filter the url and assign special url characters to dedicated servers
example:
sticky http-header GET ST-URL_STICKYFARM
replicate sticky
serverfarm domain.de
8 static header-value "" rserver SERVER1
16 static header-value "" rserver SERVER2
if "urlpattern1" appears in the http-header your packets will be send to SERVER1
if "urlpattern2" appears in the http-header your packets will be send to SERVER2
details you can find at:
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A2/configuration/slb/guide/slbgd.pdf
page 5-52
Thanks - I ended up opening a case and was provided this link:
http://cisco.com/en/US/products/hw/modules/ps2706/products_configuration_example09186a00809c3048.shtml
The document has a few flaws like making sure you filter on /.* and not /*
I did try this and it works - this tied it altogether were other docs kept it to separate to understand.
