ACE Loadbalance on same interface
scott-goodwin
Level 3
Level 3
Hi Guys,
I am tryign to deploy a solution where by i have 5 servers sat behind the ACE in a routed fashion. There are static nats to these servers for management.
3 of the servers are standard web farm.
Now these 3 servers need to speak to a VIP setup on the ACE to loadblance the traffic between the remaining 2 servers for CMS. Is this possible with them all on the same vlan?? I have tried setting up a VIP server vlan side (no joy) Tried connecting to a vip on the Client side from the servers (no joy).
Any help would be much appreciated.
Config to follow
Gilles Dufour
you need to configure client nat when doing this. Otherwise the server response will directly go the client_server which will reject it because not coming from the vip.
Gilles.
Hi Giles,
The config is attached, as you can see I have incoming nats for management of the servers, hence I initially pointed the servers to a vip on the 250.x side of the ace, however this doesnot work.
As can be seen I also set up a vip on the 240.x side for the DIIOP service.. but this doesn't function either???
Scott
How can i setn up client Nat, when i Am already natting for management purposes??
Scott
You can try this:
-. Create the VIP in the server side.
-. Then Nat all traffic hitting that VIP. You can do that with the command "nat dynamic" inside of the Policy map.
Example:
policy-map multi-match L3L4_LOADB
class CLASS_MAP
loadbalance vip inservice
loadbalance policy L7_LOADB
loadbalance vip icmp-reply active
loadbalance vip advertise active
nat dynamic 1 vlan 118
interface vlan 118
bridge-group 118
no icmp-guard
access-group input ALL
access-group output ALL
nat-pool 1 10.0.0.3 10.0.0.3 netmask 255.255.255.255 pat
no shutdown
