ACE Loadbalance ssl match header
jbbouillet
I created several rules to balance on a specific server somes apps. Everythings works great in http but no in https.
In my example, i would like https://www.app2.com/ to be redirected to my server2 but it's always using the default rules instead of the
L7CLASSSrv2. Today www.app1.com is well redirected. All other apps are correctly loadbalance with the stickyness effect but I can't handle the https connections.
class-map match-all L4-WEB-IP
      2 match virtual-address xxxx tcp eq www
class-map match-all L4-WEBHTTPS-IP
      2 match virtual-address xxxx tcp eq https
class-map type http loadbalance match-any L7CLASSSrv1
      2 match http header Host header-value "www.app1.com/*"
class-map type http loadbalance match-any L7CLASSSrv2
      2 match http header Host header-value "www.app2.com/*"
policy-map type loadbalance http first-match WEB_L7_POLICY
      class L7CLASSSrv1
           serverfarm SINGLE_WEB1
           insert-http X-FORWARDED-FOR header-value "%is"
           insert-http x-forward header-value "%is"
           insert-http X-FORWARED-FOR header-value "%is"
      class L7CLASSSrv2
           serverfarm SINGLE_WEB2
      class class-default
           sticky-serverfarm SGROUP
policy-map multi-match WEB-to-vIPs
      class L4-WEB-IP
           loadbalance vip inservice
           loadbalance policy WEB_L7_POLICY
           loadbalance vip icmp-reply active
           nat dynamic 1 vlan xxxx
           appl-parameter http advanced-options HTTP_PARAMETER_MAP
      class L4-WEBHTTPS-IP
Thanks for your help.
JB
vpurbiya
Hi John
One is you want to handle the traffic SSL termination by ACE or the actual servers .
If on ACE, you need to import the SSL cert/key on ace and then try the same.
today the ssl trafic termination is manage by the webservers and it works well.
I just want for a specific app to balance on a specific server in https as i do in http.
Hi Jean-Baptiste
The problem you hit is that you want to search for some information in HTTP header. It works perfectly well with HTTP, however in case of HTTPS this header is encrypted, so ACE simply can't get anything from it. Only one way to have it working - it's doing decryption on ACE.
What you can do , if you don't want to touch your servers, it's End-to-End SSL on ACE. This is an implementation when client initiate HTTPS connection, it's got terminated and decrypted on ACE and then ACE initiate new SSL connection to a server.
In result traffic in encrypted everywhere and you don't need to do any reconfiguration on server as it still will get HTTPS requests.
You can find an example of such configuration here :
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_configuration_example09186a00809c6f37.shtml
Thanks for your feedback, I understand now why it's not working, I thought that url was not in an encrypted field  for the ace. I will look at the article you linked in detail.
