ACE - MAX PARSE LENGTH
Dave Ng
Recently, we have tried to migrate one of the web services that is fronted by the Cisco ACE 4710 and we observed that some of the HTTP packets were dropped by the ACE 4710 as the maximum parse length (e.g. HTTP header) exceeded the default length of 4096 bytes.
We’ve resolved the issues by configuring a HTTP parameter to accept HTTP packets with parse length exceeding 4096 bytes.
Sample of configuration
parameter-map type http http_parameter_map
  case-insensitive
  persistence-rebalance
  set header-maxparse-length 8192
  set content-maxparse-length 9192
  length-exceed continue
Does anyone know what is the recommended parse length to be configured on the Cisco ACE 4710 and are there any security or performance implications to configure the load balancer to accept HTTP packets that exceed the maximum parse length?
Kanwaljeet Singh
Hi Dave,
By default the max parse length as you know is 4096. If ACE has to look in for a cookie or something else in header beyond that then you need to increase the parse length accordingly. Maximum you can set is 65535. If the traffic still gets dropped and you see increase in dropped counter due to max parse length exceeded, then you can configure length-exceed continue which i see you have already done.
Kanwal
Cesar Roque
Level 8
Level 8
Hi Dave,
There is no really a recommended parse-length because it depends more in the application and how it behaves. If you increase the parse-length the ACE has to buffer more to look what it needs to take the loadbalance decission, so it could be a little bit slower.
Cesar R
ANS Team
--------------------- Cesar R ANS Team
