ACE Mod20 interface vlan
c-fwagner
Community Member
is it possible to setup the service-policy on the server side vlan interface and still have it available for clients with a client subnet ip?
What i'm currently trying it to reach is the other side through the ace. And ping the interface vlan's in a context. But i don't get any answer.
Trying to reach the interface vlan adress 2.1.1.1 from a host in vlan1, but with no success. I can ping the interface vlan 1 though and can route through the module also.
Setup is simple as that:
access-list anyone line 18 extended permit ip any any
interface vlan 1
desc client vlan
  ip address 1.1.1.1 255.255.255.0
  alias 1.1.1.2 255.255.255.0
  access-group input anyone
  service-policy input remote-mgmt
  no shutdown
interface vlan 2
desc server vlan
  ip address 2.1.1.1 255.255.255.0
   alias 2.1.1.2 255.255.255.0
  no shutdown
Greetings,
Frank
Sean Merrow
Level 10
Level 10
Hi Frank,
Service-policies need to be applied to the incoming/ingress interface, hence the 'input' keyword when applying them.  As for ping, by design, the ACE will not allow you to ping a remote interface on the ACE.  In other words, a host on VLAN 1 will be able to ping IP 1.1.1.1, but not 2.1.1.1.  A host on VLAN 2 will be able to ping 2.1.1.1, but not 1.1.1.1.
Hope this helps,
Sean
Hi Sean,
Thanks, that was the answer i was looking for. Only incoming traffic for an interface that is in the incoming direction, is a possible connect.
This is a design limitation or feature.
It's possible to configure global service-policies, to have the VIP available on any interface by default also.
Thanks a lot,
Frank
Hi Frank,
Depends on who you ask.  Officially, it is a secuirty feature.
This is a true statement.
- Sean
