Showing results forĀ
Search instead forĀ
Did you mean:Ā
ACE module contents of disk: erased
arthurlove
well - infact the whole lot - all config wiped, all that is left in the disks is the  software and a few other files. I read from core: a file called
ixp1_crash.txt which was time exactly one hour and 2 mins before info in ha_mgr logs showed the device failing over.
any ideas ???
Ta muchly
rodrguti_2
I will recommend to open a TAC case in order to analyze the core file, and it seems to be a HW issue, but it would be better to check with TAC in order to have a solid answer.
Cheers,
Rodrigo.
