ACE module failed secondary ACE did not take over.
krunal_shah
Show Tech from the 6509 switch the ACE module lives in
ACE#show module
Mod Ports Card Type Model Serial No.
1 3 Network Analysis Module WS-SVC-NAM-1 SAD115204BS
2 1 Application Control Engine Module ACE20-MOD-K9 SAD1204075T
3 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL1204E77M
4 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL1205EJSV
5 5 Supervisor Engine 720 10GE (Active) VS-S720-10G SAL1205EKKW
Mod MAC addresses Hw Fw Sw Status
1 001d.a223.0886 to 001d.a223.088d 4.1 7.2(1) 3.6(1a) Ok
2 001e.f7a1.4b48 to 001e.f7a1.4b4f 2.3 8.7(0.22)ACE A2(1.2) MajFail
3 001e.f7c5.92f0 to 001e.f7c5.931f 2.7 12.2(14r)S5 12.2(33)SXH1 Ok
4 001e.f760.ea10 to 001e.f760.ea3f 2.7 12.2(14r)S5 12.2(33)SXH1 Ok
5 0019.e8bb.0314 to 0019.e8bb.031b 2.0 8.5(2) 12.2(33)SXH1 Ok
Mod Sub-Module Model Serial Hw Status
3 Centralized Forwarding Card WS-F6700-CFC SAL1204DVCR 4.0 Ok
4 Centralized Forwarding Card WS-F6700-CFC SAL1204E4US 4.0 Ok
5 Policy Feature Card 3 VS-F6K-PFC3C SAD120404S9 1.0 Ok
5 MSFC3 Daughterboard VS-F6K-MSFC3 SAD120407J6 1.0 Ok
Mod Online Diag Status
1 Pass
2 Major Error
3 Pass
4 Pass
5 Pass
The standby ACE can not detect the Active unit, but has failed to go HOT and carry traffic.
ACE2/Admin# show ft group sta
FT Group : 1
Configured Status : in-service
Maintenance mode : MAINT_MODE_OFF
My State : FSM_FT_STATE_STANDBY_COLD
Peer State : FSM_FT_STATE_UNKNOWN
Peer Id : 1
No. of Contexts : 1
FT Group : 116
Peer Id : 1
No. of Contexts : 1
FT Group : 180
Peer Id : 1
No. of Contexts : 1
FT Group : 181
Peer Id : 1
No. of Contexts : 1
FT Group : 182
Peer Id : 1
No. of Contexts : 1
ciscocsoc
Level 4
Level 4
In a normal FT situation I'd expect to see an active and a hot standby. If one of the contexts is in state FSM_FT_STATE_STANDBY_COLD then this implies that synchronisation between the ACE blades has been broken.
Synchronisation can be broken by differences in the files in a context. Files include scripted probes, SSL certificates and SSL certificate keys. Until both contexts have identical files then synchronisation will not happen.
To resolve this problem, ensure that the files are the same. On both contexts check the configs line-by-line for differences and check the directories for files.
If replication does not restart automatically then you will need to restart it from each of the ACTIVE contexts.
conf t
no ft auto-sync running-config
no ft auto-sync startup-config
Cathy
Thank you Cathy for your reply,
FYI.. Cu see the peer priority on the standby unit to a lower value, however it had no affect on the HA state. See below for more details.
ft group 116
peer 1
priority 95
peer priority 85
associate-context <>
inservice
ft group 180
peer 1
priority 95
peer priority 85
associate-context SHARED
inservice
ft group 181
peer 1
priority 95
peer priority 85
inservice
ft group 182
peer 1
priority 95
peer priority 85
inservice
ft group 183
peer 1
priority 95
peer priority 85
inservice
ft group 184
peer 1
priority 95
peer priority 85
inservice
ft group 185
peer 1
priority 95
peer priority 85
inservice
ft group 186
peer 1
priority 95
peer priority 85
inservice
ft group 187
peer 1
priority 95
peer priority 85
inservice
ft group 188
peer 1
priority 95
peer priority 85
inservice
We are now taking it out of the FT group to make the secondary unit a stand alone. This seems to have allowed traffic to resume normal operation.
ft group 116
peer 1
priority 95
peer priority 85
no inservice
ft group 180
peer 1
priority 95
peer priority 85
no inservice
ft group 181
peer 1
priority 95
peer priority 85
no inservice
ft group 182
peer 1
priority 95
peer priority 85
no inservice
ft group 183
peer 1
priority 95
peer priority 85
no inservice
ft group 184
peer 1
priority 95
peer priority 85
no inservice
ft group 185
peer 1
priority 95
peer priority 85
no inservice
ft group 186
peer 1
priority 95
peer priority 85
no inservice
ft group 187
peer 1
priority 95
peer priority 85
no inservice
ft group 188
peer 1
priority 95
peer priority 85
no inservice
All virtual contexts are now at INIT
see the attachment part2.txt
Do you have an ft interface defined in your admin contexts and is it active and linked to peer group 1? If you have an active ft interface is the vlan plumbed through between the ACEs?
E.g. in my admin context:
ft interface vlan 294
ip address 192.168.54.73 255.255.255.252
peer ip address 192.168.54.74 255.255.255.252
no shutdown
ft peer 1
heartbeat interval 300
heartbeat count 10
ft-interface vlan 294
Kind Regards
Cathy
HI ,
Once you've configured redundancy on the ACEs, there's an active one, and a stand-by one. Ok, this is simple. However, there are some times configuration synch fails, and here's what I observed.
Once redundancy is configured this way :
ACTIVE ACE
ft group 1
peer 1
priority 200
peer priority 101
associate-context CONTEXT1
inservice
STANDBY ACE
ft group 1
peer 1
priority 101
peer priority 200
inservice
SO my questionn to you do you have change the peer priority to higher and priority to be lower on the standby ace , or have you copied the config same on both the active as well as standby, please confirm me.
As usual, the active one has the highest priority. Now I want this redundancy to be HOT, i.e. sessions remain up during a switchover as they are mantained in sync by the peers.
Typing a show ft group det on the master ACE you could (as I did) see two types of redundancy :
Peer State : FSM_FT_STATE_STANDBY_HOT
or
Peer State : FSM_FT_STATE_STANDBY_COLD
Cold standby state means that sessions during the switchover will be dropped, and that, for some reason, configuration sync failed, so configurations are not even equal between the two peers, and further changes on the master will not be sent to the slave.
Typical reasons for configurations' sync to fail are :
A scripted probe needs its script file on the ACE's disk0:,
the standby ACE may not have this file on his disk0:
Interfaces are not configured the same way (missing some interface vlan? as told above by cathy)
Svcl groups on the Catalysts hosting the ACE may not pass the same vlans to the two peers.
However, if you made one of these mistakes, as I did, you have your standby ACE in COLD standby state, what to do now ?
Even copying manually the configuration on the second ACE, it will never switch by itself in HOT standby state.
The solution is quite easy :
Solve all the issues that caused the configuration sync to fail (see above).
On the standby ACE, switch off and then on (rapidly) the ft group of the context :
ACE-02/Admin#conf t
ACE-02/Admin(config)#ft group 1
ACE-02/Admin(config-ft-group)#no inservice
ACE-02/Admin(config-ft-group)#inservice
Now you will see the standby ACE erase all of its configuration and then start back to copy it from the master ACE. At the end, you should see on the master :
FT Group : 1
My State : FSM_FT_STATE_ACTIVE
My Config Priority : 200
My Net Priority : 200
My Preempt : Enabled
Peer Config Priority : 101
Peer Net Priority : 101
Peer Preempt : Enabled
Peer Id : 1
Last State Change time : Fri Aug 3 06:22:17 2007
Running cfg sync enabled : Enabled
Running cfg sync status : Running configuration sync has completed
Startup cfg sync enabled : Enabled
Startup cfg sync status : Startup configuration sync has completed
No. of Contexts : 1
Context Name : CONTEXT1
Context Id : 2
Note : During this process configuration is inhibited even on the master ACE.
Hope it will solve your problem.
If you still face problem please speak back to me.
Please rate if find any useful.
Sachin Garg
