ACE Module - HTTP Probe failure
cisco_lite
Level 6
Level 6
I have configured the http probe with expect status 200 202, but the probe fails despite availability of the port on rserver.
I tried head/get method to see the return code, and it came back with HTTP1.1/302. How can I configure an http probe to understand HTTP 302 code as success return.
Thanks.
under the probe, configure a "header Host www....."
Gilles.
10 Replies 10
Gilles Dufour
set the expect status to 302.
If you do a 'show probe detail' what kind of error do you see displayed ?
No. Passed states : 3 No. Failed states : 3
No. Probes skipped : 9 Last status code : 0
No. Out of Sockets : 0 No. Internal error: 0
Last disconnect err : -
Gilles.
I changed the expect status value as below
probe http TEST-HTTP
interval 30
passdetect interval 10
request method head
expect status 302 302
The probe is still failing with the log message
Apr 20 2009 12:04:35 : %ACE-3-251010: Health probe failed for server 192.168.1.10 on port 80, received invalid status code
On 'show probe detail' it shows the last status code as 400 which means Bad Request
--------------------- probe results --------------------
probe association probed-address probes failed passed health
serverfarm : TEST-APP
real : TEST-SERVER1[80]
192.168.1.10 27 27 0 FAILED
Socket state : CLOSED
No. Passed states : 0 No. Failed states : 1
No. Probes skipped : 0 Last status code : 400
Last disconnect err : Received invalid status code
Last probe time : Mon Apr 20 12:05:33 2009
Last fail time : Mon Apr 20 12:00:53 2009
Last active time : Never
The http page is showing perfectly on the web browser. Also, using the http head/get tool, I can see that 302 is returned.
What could be the problem.
Regards.
shouldn't you specify the url of the page the ACE should get (head)?
fe: request method head url /index.html
I have entered request 'request method head url /' which shows in the running config as 'request method head' i.e. default.
Using index.html etc is not mandatory I believe as '/' checks for any web service.
I found this in the config guide for probing:
"By default, the HTTP request method is a GET with the URL “/”. If you do not configure a URL, the probe functions as a TCP probe."
Is your server listening to another port then 80?
Yes, the service is running. If I do a telnet on port 80 it opens up. The head/get utility is coming back with 302. And the page is showing on the web browser.
I sniffed the traffic going to the rserver and noticed invalid SYN request to the webserver i.e. I don't see '/' request in the packet capture. Below is the serverfarm config
serverfarm host TEST-APP
rserver TEST-SERVER1 80
probe TEST-HTTP
inservice
However, similar probe is working fine in admin context on another rserver. The only difference is that the probe is on a custom HTTP port and not default port 80. Can that cause a difference.
To add onto the above, the web server is on IIS 6.0 (Windows Server 2003) and the error returned on the probe is HTTP 400 - Bad Request (Invalid Hostname).
Has anyone experienced this ?
Gilles.
I had similar problems with an AS 400.
Had to configure the host.
So I prefere to use the expect 400
