HTTP header insertion problem with ACE
lukaszkhalil
Level 4
Level 4
I try to configure the HTTP header insertion feature based on the action-list type modify http. Unfortunately it does not works.
The config looks like that
action-list type modify http TEST
header insert both Host header-value test:test.
I added this action-list to the correct policy-map.
When I checked the snifer output on the server side, there is no test value in the HTTP header.
I test the same feature based on the "insert-http" command in the policy-map and this one works.
Could anybody help me with this problem?
Thank you in advance
Lucas
4 Accepted Solutions
configure persistence rebalance with a parameter-map.
G.
Hi Lukas,
Add a new parameter-map named PRMAP_PERST_REBLNC and add this to the policy map using command appl-parameter http advanced-options PRMAP_PERST_REBLNC as shown below:
action-list type modify http test-insert
header insert both My-Header header-value test
header insert both SSL header-value TRUE
policy-map type loadbalance http first-match HtppInsert
class class-default
serverfarm linux1-80
action test-insert
policy-map multi-match SLB1
class VIP-122-80
loadbalance vip inservice
loadbalance policy HtppInsert
loadbalance vip icmp-reply active
loadbalance vip advertise active
loadbalance vip advertise metric 1
connection advanced-options SetTos
parameter-map type http PRMAP_PERST_REBLNC
persistence-rebalance
Hope this will make all the packets are inserted with the http header not the first one only.
If it works then plz inform.
Kind Regards.
Sachin Garg
Instead of persistence-rebalance in your parameter map. Use header modify per-request in the parameter map. This introduces less overhead as we don't need to make a load balance decsion just insert the header.
Lucas,
analyzing data requires time, cpu, memory ... resources.
So we try to only analyze a minimum of data.
Without persistence rebalance, once we have made our loadbalancing decision, we simply switch the traffic without looking into the data.
This is the best option to achieve best performance.
By configuring 'persistence rebalance' you forces ACE to inspect every request.
You'll get lower performance but since we inspect all request we are able to insert the header to each of them.
Gilles.
11 Replies 11
Gilles Dufour
I just gave it a try in my lab and it works.
header insert both My-Header header-value "gilles"
header insert both Host header-value "192.168.30.24:80"
class class-default
action test-insert
class VIP-122-80
My version: A2(1.4a)
G.
Ok thank you. I did my tests on version A2(1.4) so I'll try to do that on A2(1.4a)
Lucas
I've done some tests on A2(1.4) and I confirm that the feature works, but the problem is that the new header field in being inserted only into the first packet of the flow. The rest of the packets do not have this parameter set.
Do you know how it can be fixed ?
Lucas
Hi Lukaszk,
Enter an unquoted text string with no spaces and a maximum of 255 alphanumeric characters in the expression part as shown below.
header insert both My-Header header-value gilles
header insert both Host header-value 192.168.30.24:80
header insert both Host header-value www.cisco.com
Kind Regards,
Sachin Garg
He
I tried to do that, but the results are the same.
My config is as below
I attached this action-list to the SSL policy-map, and what I saw is that the new headers appeared only in the first HTTP packet of the flow.
Lucas
G.
Hi Lukas,
class class-default
action test-insert
class VIP-122-80
Kind Regards.
Sachin Garg
Hello
I've done a test and it works as well as the persistent-rebalance.
Could you please explain to me why when using persistent-rebalance I see the header value in each packet ?
Regard
Lucas
Lucas,
Gilles.
ok, now it is clear for me.
Thank you
Lucas
