ACE Module HTTP Rewrite Problem
m.imaduddin
Level 2
Level 2
Hi All,
We are currently testing ACE Module feature to do http rewrite on backend server.
Users will access http://VIP/test, and ACE should rewrite the request to http://VIP/prod
I have checked config-guide and Netpro case-studies but no result. User still cant access http://VIP/test, but they can access http://VIP/prod directly
These are the configurations:
rserver host S1
  ip address 10.2.2.2
  inservice
serverfarm host SF-PROD
  probe WEB_SERVERS
  rserver S1
    inservice
class-map type http loadbalance match-any L7CLASS-PROD
  2 match http url /test/*
policy-map type loadbalance http first-match WEB_L7_POLICY
class L7CLASS-PROD
    serverfarm SF-PROD
    action HTTP_MODIFY
action-list type modify http HTTP_MODIFY
  header rewrite request Host header-value "(.*)test(.*)" replace "%1prod%2"
Please check my configuration
Imad
sivaksiv
You can redirection for this instead of rewrite. Check link below for sample config.
https://supportforums.cisco.com/thread/345693
Siva
sivaksiv
Siva
Hi Siva,
I can access the server correctly by using HTTP redirect..But still im still wondering why cant i configured it with rewrite.
Btw thank you for your informations
Best Regard,
Imad
Hi Imad,
Glad it worked. Actually url rewrite is still not possible on ACE and expected to be in future release. If it is actually in a header such as location then yes, however if it is in  the request uri then no since that is not a header as ACEcannot do url rewrite.
Siva
