ACE Module Implementation
sidcracker
Level 4
Level 4
Hi Everyone,
I have been asked to implement a Failover ACE Module on a pair of 6509. I have been working on the ACE appliance for some time now during the maintenance activities but never really implemented one from the scratch.
Does any one know of any documentation that provides a step by step approach towards configuring an ACE module on a 6500 switch.
Sid
Marvin Rhoads
The failover bit is really quite simple. The administration guide has a chapter on just that.
If you've never done one from scratch, I'd recommend just working through the configuration guides for the version of softare you're running. They are all listed on the product support page.
There are also some overall design guides and a quick start guide on the product Wiki page.
