ACE module only inserting X-Forwarder Header on first packet
scott-goodwin
Level 3
Level 3
As above, I have a strange problem where if I use my proxy server to access an LB VIP then it is inserting the X-forwarding header for Each GET request.
However if I make the request direct from my PC (not via Proxy) it inserts the header on the first packet but no subsequent packets unless I restart the browser.
Any ideas????
Scott
Sean Merrow
Level 10
Level 10
Hi Scott,
In the ACE documentation, check out the section on Configuring the ACE to Modify Headers on Every HTTP Request or Response.
I hope this helps,
Sean
Sean Merrow
Level 10
Level 10
Hi Scott,
I hope this helps,
Sean
Thanks Sean, that has cured our initial problem in the test enviroment, just rolling it out to live network so fingers crossed
Scott
