ACE Module Question
jteixido
Level 3
Level 3
I have the following configuration:
policy-map type loadbalance first-match test
class L7-URL
sticky-serverfarm test
insert-http src-ip header-value %is:%ps:%id:%pd
class class-default
serverfarm test
Does the class class-default need to be in the above configuration? The reason I as is because I see it in some examples and not in others.
John...
class-default act as a last resort under policy configuration. If there are multiple classes to check against the traffic then policy will compare traffic against all the classes and if there is no match then actions for class-default will be used.
In your case
ACE will look for the condition in "class L7-URL" , if it matches then it will use sticky-group test (which should have a serverfarm associated to it). Serverfarm under the sticky group will be used if the client request matches the class L7-URL.
If client request doesnt match the condition in "class L7-URL" then server farm test (under class-default) will be used.
Syed iftekhar Ahmed
