ACE Multi-Context Shared VLAN?
davemit
Level 2
Level 2
I will be deploying the ACE with two virtual contexts in routed mode.  Each context will have its own separate server VLAN, but I am wondering if I can share the Client side VLAN  between contexts?  Is this possible, or does each context need it's own client VLAN for routing back to the network core?
I was planning on using VIPs selected from the Client VLAN subnet.  If I do share that VLAN between two contexts, would there be any issues with each context responding correctly to the VIP's configured on it?
Thanks!
Yep, you are right. Cisco says its forbidden by security reasons. So if you want them to talk together you better use two seperate VLANs.
11 Replies 11
Cesar Roque
Level 8
Level 8
Hi David,
You can use the same VLAN on different Context but each Context should have its own IP address.
http://tools.cisco.com/squish/880AF
Cesar R
--------------------- Cesar R ANS Team
Thanks for the answer.  Are there any issues with the two contexts responding to VIP's when they're assigned from the shared client VLAN?
Yes, you can not access the VIP on context A from context B. Or the VIP of context B from context A. That's forbidden by security reasons.
What do you mean by "can not access the VIP"?
If servers behind Context A need to talk to a VIP in Context B, will it not work in this scenario?
Thanks!
Wow, okay thanks.  I will definitely set up separate VLANs for this!
Hello David
This is correct.  however, a easy way to fix this and still using the same VLAN is configuring the servers in both Context.
Cesar R.
Huh?  The Real Servers are in separate VLANS (one in each Context).  How would I "configure the servers in both contexts"?
Hi David,
To expalin this better, I have this two Contexts:
context test
  allocate-interface vlan 144
  member test
context test2
  member test
The config of test is this:
rserver host test
  ip address 10.198.16.93
  inservice
serverfarm host test
  rserver test
    inservice
class-map match-all test
  2 match virtual-address 10.198.44.180 tcp any
policy-map type loadbalance first-match test
  class class-default
    serverfarm test
policy-map multi-match test1
  class test
    loadbalance vip inservice
    loadbalance policy test
    nat dynamic 1 vlan 144
interface vlan 144
  ip address 10.198.44.150 255.255.255.0
  access-group input Allow_Access
  nat-pool 1 10.198.44.180 10.198.44.180 netmask 255.255.255.0 pat
  service-policy input NSS_MGMT
  service-policy input test1
  no shutdown
ip route 0.0.0.0 0.0.0.0 10.198.44.4
The config of test2 is:
rserver host test
  ip address 10.198.44.24
  inservice
  rserver test
    inservice
  2 match virtual-address 10.198.44.181 tcp any
  class class-default
    serverfarm test
  class test
interface vlan 144
  ip address 10.198.44.160 255.255.255.0
  nat-pool 1 10.198.44.181 10.198.44.181 netmask 255.255.255.0
  no shutdown
From the rserver 10.198.44.24, I can get to the VIP of  Context test 10.198.44.180.
Here is the output:
ACE-M3/test# sh conn
total current connections : 2
conn-id    np dir proto vlan source                destination           state
2584127    2  in  TCP   144  10.198.44.24:52872    10.198.44.180:80      ESTAB
2584134    2  out TCP   144  10.198.16.93:80       10.198.44.180:1029    ESTAB
The condition here is that the ACE is not the default gateway of the servers.  There is another L3 device that routes the traffic to the VIP.
Cesar R
Got it, thanks Cesar.  The difference is that you are running One-Arm Mode on both contexts.  I will be in-line routed mode, so if I understand properly I will need to have separate client VLANS for both contexts in order to avoid this problem.
nickjacobs
Level 2
Level 2
You can add a host route for the VIP of the other context via the upstream router on the context you want access from - it works (but its a bodge that relies on redirects and chews bandwidth!). Also if you run one context on one appliance in a HA pair, and the other context on another is another even bigger bodge that also works.
Re-address to non shared client VLAN is really the only solid way as you say.
