"access-group input ANY" problem
iamluheng
We are using OVH configure help guide, http://help.ovh.ie/VrackLoadBalancingACESimple
We have following setup:
vlan 1515 is where the load balancer is, and the vlan 2911 is where all the servers are. There is a 199.239.227.0/24 public IP assgin to the ACE.  The ACE use active/passive FT.
The purpose of the config is equally distribute http traffic to 5 real servers based on amount of connection it has.
And according to OVH guide, we should have "access-group input ANY" in both vlan to make it work. However, when we put an "access-group input ANY" with vlan 1515(the one where ACE and all the public IP is), all the IP stop responding including the one used to connect to the ACE. once we remove the "access-group input ANY" line, the ACE is connectable as well as ALL the vIPs are all pingable. however we still not able to connect the ACE with the http port, and telnet shows the port 80 is not open.
Here is the config output of our server.(with "access-group input ANY" enable in vlan 1515, and all the vIPs is not responding to Ping as well as ACE is not connectable.)
access-list ANY line 8 extended permit icmp any any
access-list ANY line 16 extended permit ip any any
probe tcp PROBE_TCP
  interval 30
  passdetect interval 60
rserver host abc
  ip address 172.16.0.1
  inservice
rserver host abcd
  ip address 172.16.0.2
  inservice
rserver host abcde
  ip address 172.16.0.3
  inservice
rserver host abcdef
  ip address 172.16.0.4
  inservice
rserver host abcdefg
  ip address 172.16.0.5
  inservice
serverfarm host FARM_WEB
  predictor leastconns
  probe PROBE_TCP
  rserver abc
    inservice
  rserver abcd
    inservice
  rserver abcde
    inservice
  rserver abcdef
    inservice
  rserver abcdefg
    inservice
parameter-map type http HTTP_PARAMETER_MAP
  persistence-rebalance
class-map match-any L4-WEB-IP
  2 match virtual-address 199.239.227.1 tcp eq www
  3 match virtual-address 199.239.227.2 tcp eq www
  248 atch virtual-address 199.239.227.249 tcp eq www
class-map type management match-all REMOTE_ACCESS
  2 match protocol ssh any
class-map type management match-all TEST
  2 match protocol icmp any
policy-map type management first-match REMOTE_MGMT_ALLOW_POLICY
  class REMOTE_ACCESS
    permit
policy-map type management first-match TEST_ALLOW
  class TEST
    permit
policy-map type loadbalance http first-match WEB_L7_POLICY
  class class-default
    serverfarm FARM_WEB
    insert-http x-forward header-value "%is"
policy-map multi-match WEB-to-vIPs
  class L4-WEB-IP
    loadbalance vip inservice
    loadbalance policy WEB_L7_POLICY
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 2911
    appl-parameter http advanced-options HTTP_PARAMETER_MAP
interface vlan 1515
  ip address 199.239.227.250 255.255.255.0
  alias 199.239.227.249 255.255.255.0
  peer ip address 199.239.227.251 255.255.255.0
  service-policy input REMOTE_MGMT_ALLOW_POLICY
  service-policy input WEB-to-vIPs
  no shutdown
interface vlan 2911
  ip address 172.31.255.250 255.240.0.0
  alias 172.31.255.249 255.240.0.0
  peer ip address 172.31.255.251 255.240.0.0
  nat-pool 1 172.31.255.248 172.31.255.248 netmask 255.240.0.0 pat
  service-policy input TEST_ALLOW
  no shutdown
ft track interface  VLAN1515
  track-interface vlan 1515
  peer track-interface vlan 1515
  priority 50
  peer priority 5
ip route 0.0.0.0 0.0.0.0 199.239.227.254
username XXX password 5 XXX  role Admin domain default-domain
Here is the config in the OVH website:
rbx-99-6k-ace-1/vrack1234# show running-config
Generating configuration....
probe tcp PROBE_TCP
interval 30
rserver host testvrack1.ovh.net
conn-limit max 50000 min 40000
inservice
rserver host tesvrack2.ovh.net
inservice
probe PROBE_TCP
rserver testvrack1.ovh.net
inservice
class-map match-all L4-WEB-IP
2 match virtual-address 178.33.8.65 tcp eq www
class REMOTE_ACCESS
permit
class TEST
permit
class class-default
serverfarm FARM_WEB
class L4-WEB-IP
nat dynamic 1 vlan 1234
interface vlan 123
ip address 178.33.8.77 255.255.255.240
no shutdown
interface vlan 1234
nat-pool 1 172.31.255.250 172.31.255.250 netmask 255.240.0.0 pat
no shutdown
5 Replies 5
Daniel Arrondo Ostiz
Good morning,
Adding the ACL to allow traffic is a must. The ACE includes a implicit deny all on the interfaces, so, the ACL is required to override this.
With this said, I suspect that your issue may be due to a faulty FT configuration leading to an active/active situation when the ACL is configured. I would check this first.
Daniel
Thanks very much for reply.
I found the problem.
Any time put more than 214 IPs in the interface, it will
get disconnected.
    2 match virtual-address 1**.2**.227.1 tcp eq www
    3 match virtual-address 1**.2**.227.2 tcp eq www
    214 atch virtual-address 1**.2**.227.213 tcp eq www
If we put line "215 match virtual-address 1**.2**.227.214
tcp eq www", the interface will disconnected. to put it
back, two ways: 1. remove the 215 line. 2. remove ACL from
interface 1515.
Please let us know if it is a bug.
Which version is running on the ACE module ? You should alert OVH and ask them to open a case.
Good morning,
Yes, that looks like a possible bug. As Surya suggested, the best approach would be to open a TAC service request to have it investigated further.
I have two questions for you:
  • Why do you need to define more than 200 IP addresses on a single class? You are sending all the connections to the same serverfarm, so why not using a single VIP address?
  • The ACE provides the option to define a VIP as a range of addresses (by configuring a netmask after the address). Any specific reason why you are not using this instead of defnining the whole range? Doing this would probably solve your issue.
Daniel
Good morning:
Thanks for replying Surya and Daniel.
Daniel, to answer your two questoin.
We have about 700+ website on the serverfarm, and we are trying to give dedicated IP for each of the site.
We are worrying two point.
1. if we define the whole range, it will conficts with interface 1515's IP(as the interface use public IP inside the /24 as well).
2.  "2 match virtual-address 1**.2**.227.0/255.255.255.0 tcp eq www", to be speicific, are you suggesting put this line in the class map and clear the rest?
