ACE multi domain SSL certificate
silk
Hello there,
this may sound an obvious question maybe, but I didn't find a proper answer:
does ACE supports SSL termination using a multi domain certificate? CN + several SANs
and how do I issue a certificate request on the LB for this kind of cert?
Thanks in advance.
S.
pablo.nxh
Level 3
Level 3
Hello S.
Yes the ACE does support SAN certificates, the process to import and configure it's the same as if you would be importing
a "regular" SSL cert.
About the CSR for multiple domains I've checked the latest version release notes and it seems the feature has not been added yet. When I've been asked to create a SAN CRS I always do it using OpenSSL, here is a link that explains what you need to do in order to get your pem files.
http://xrl.us/bkrr56
__ __
Pablo
pablo.nxh
Level 3
Level 3
Hello S.
__ __
Pablo
Pablo,
thank you very much for your reply, that was just the information I was missing
S.
