Using URL maps to search for a particular sub-domain in a URL
sgonsalv
Hi Guys,
Seem to be having some trouble with URL maps, and trying to search for a particular sub-domain in a URL.  Let me explain:
We will have a number of applications frontended by our CSM VIP such as:
sftp.poc.monash.edu.au
callista.poc.monash.edu.au
I'm trying to get the CSM via policies and URL maps, to search for say "callista" and direct this traffic to a particular farm as below...however when i use the match statement the connections are dropped.
map CALLISTA url
  match protocol http url *callista*
map CALLISTA-SFTP url
  match protocol http url *sftp*
policy CALLISTA
  url-map CALLISTA
  sticky-group 197
  serverfarm CALLISTA
policy CALLISTA-SFTP
  url-map CALLISTA-SFTP
  sticky-group 198
  serverfarm CALLISTA-SFTP
vserver CAL-POC-DECVIP
  description decrypt VIP for SERVERFARM CAL-POC
  virtual 172.16.11.116 tcp www
  persistent rebalance
  parse-length 4000
  slb-policy CALLISTA
  slb-policy CALLISTA-SFTP
  inservice
So i'm wondering if there is a better regular expression statement i can use to ensure that all the traffic that has "callista" in the URL is directed to a particular farm?
thanks
Sheldon
sgonsalv
Having a read through the CSM config guide I think i may have found the answer.  I noticed that the URL maps only work on searching a "path' after the domain e.g. the presence of either "index" or "cep":
callista.poc.monash.edu.au/index.html
or
callista.poc.monash.edu.au/cep/
I've tested the above logic and this holds true....therefore there doesn't seem to be a way of searching for a "subdomain" in the URL as opposed to various bits of a "path".  That is i'd like to search for "callista" or "admissions" instead of the path
or
admission.poc.monash.edu.au
Can someone confirm this one way or another?  And if the sub-domain search is not possible, are there alternatives to getting it to work?!
thanks
Sheldon
Realised that I can use a header map instead where I can then search on the "Host" part of the HTTP header!
All good now!
Cheers
Sheldon
