ACE not forwarding SMTP/ESMTP connection correctly
edgarfc254
I am having problems with the SMTP/ESMTP connection to MS Exchange 2010 server when going via the ACE VIP. I have also tested with a serverfarm containing a single entry (1 exchange box configured) and still get the same problem. Not sure if there are any connection parameters I need to change.
ACE Software
  loader:    Version 12.2[120]
  system:    Version A2(3.5) [build 3.0(0)A2(3.5)]
Problem
- clients fail to connect to SMTP/ESMTP when making the connections through the VIP but works when connecting direct to the servers.
- telnet session to the ports behave differently
  -  sessions direct to the servers work fine (initiated either from the client PC or ACE)
$ telnet SERVER_IP 25 or 587
Trying SERVER_IP...
Connected to …
Escape character is '^]'.
220 mail.server.xyz Microsoft ESMTP MAIL Service ready at Wed, 12 Sep 2012 13:32:48 +0200
helo
250 mail.server.xyz Hello [CLIENT_IP]
quit
221 2.0.0 Service closing transmission channel
  - sessions to the VIP do not show any output. However, I get an out put after I enter a string and press enter
Trying SERVER_IP...
Connected to mail.server.xyz (SERVER_IP).
helo
220 mail.server.xyz Microsoft ESMTP MAIL Service ready at Wed, 12 Sep 2012 13:46:18 +0200
quit
Connection closed by foreign host.
Trying 137.158.154.100...
jshskjs
220 mail.server.xyz Microsoft ESMTP MAIL Service ready at Wed, 12 Sep 2012 13:46:34 +0200
500 5.3.3 Unrecognized command
quit
It seem the ACE is not passing smtp/esmtp connection requests to the server but works fine for other ports when passing through the VIP.
Cesar Roque
Level 4
Level 4
Hi Edgar,
Can you please paste the configuration you ahve for this VIP
--------------------- Cesar R ANS Team
Simple config...
rserver host EXCHANGE001
  ip address 10.2.3.101
  probe PING_EXCHANGE
  inservice
rserver host EXCHANGE002
  ip address 10.2.3.102
  probe PING_EXCHANGE
rserver host EXCHANGE003
  ip address 10.2.3.103
  probe PING_EXCHANGE
rserver host EXCHANGE004
  ip address 10.2.3.104
  probe PING_EXCHANGE
serverfarm host EXCHANGE
  description EXCHANGE SERVERS
  predictor hash address
  probe PR-EXCHANGE-HTTPS
  rserver EXCHANGE001
    inservice
  rserver EXCHANGE002
  rserver EXCHANGE003
  rserver EXCHANGE004
class-map match-all EXCHANGE-VIP
  10 match virtual-address 10.2.3.100 tcp any
sticky ip-netmask 255.255.255.255 address both EXCHANGE-STICKY
  timeout 20
  replicate sticky
  serverfarm EXCHANGE
policy-map type loadbalance first-match EXCHANGE-VIP
  class class-default
    sticky-serverfarm EXCHANGE-STICKY
policy-map multi-match EXCHANGE_POL
  class EXCHANGE-VIP
    loadbalance vip inservice
    loadbalance policy EXCHANGE-VIP
    loadbalance vip icmp-reply
NB: Only rsever EXCHANGE001 is active in the serverfarm.
Hi Edgar,
Try to configure a nat-pool in the interface VLAN using the VIP, like this:
nat-pool 1 10.2.3.100 10.2.3.100 netmask 255.255.255.0 pat
Then apply that nat-pool to the policy multi-match
  class EXCHANGE-VIP
    nat dynameic 1 vlan XX
