ACE - per context default routing
thedinuka
HI,
Can I do independent static/default routes in each context?
I want to have two virtual contexts and need to configure two different default routes in each.
Any idea on the possibility of this ?
thanks
dario.didio
Level 4
Level 4
Yes, this is no problem.
You just define static or a default route per context.
Each context has its own routing table which can be viewed by the "show ip route" command.
Hope this helps
