ACE probe for rserver
gavin han
Level 7
Level 7
Hi I've following requirement to do health check for server.
I need to add below three ports in probe with OR condition so if any of these 3 port is up along with 10292 connection should  go that  server:
10721
10722
10723
how to do this? can we setup up such health check with using script?
gavin han
Level 7
Level 7
in above: I did typo. I meant to say "can we setup up such health check without using script?"
please help.
Any help would be hightly appreciated
You will need a custom script. The supplied CHECKPORT_STD_SCRIPT should provide a reasonable starting point. You just need to implement the logic behind setting the return code.
Cathy
