ACE Reverse Proxy question
gwilliams
Community Member
Hello, I have a client that needs to reverse proxy sessions to two backend servers. Can the ACE preform reverse proxies?
Gregg,
you need to create an action-list and assign it to your policy-map
switch/Admin(config)# action-list type optimization http avs_default
switch/Admin(config-actlist-optm)# ?
Configure optimization actions:
appscope Appscope measurement against optimization
cache Cache optimization
delta Delta optimization
do EXEC command
dynamic Enable just-in-time object accelaration
end Exit from configure mode
exit Exit from this submode
flashforward Flashforward optimization
flashforward-object Flashforward object optimization
no Negate a command or set its defaults
You will probably want to use cache forward or cache dynamic.
More info at
http://www.cisco.com/en/US/docs/net_mgmt/application_networking_manager/2.0/user/guide/UG_optimization.html
Gilles.
Gilles Dufour
What do you expect from the reverse-proxy ???
Just caching ?
If so, the ACE module is not a solution but the ACE appliance C4710 will offer caching functionalities.
Gilles.
Gilles,
We do have a 4710. Attached is what we are trying to do. Can you point me in the right direction for setting this up? We are trying to reverse proxy an SSL traffic to two web servers. SSL traffic will be terminated on the ACE. I have also attached my configs, with how I have setup the VIP and server farm.
I am a switch and router guy not a load balancer expert by any means, any help or pointing to the correct docs would be very helpful.
Gregg
Gregg,
do EXEC command
More info at
Gilles.
Get rid of your chain group, if you only have the root cert, you don't need a chain group.
crypto chaingroup HBSP_CHAIN_GROUP
cert ebscert.pem
ssl-proxy service SSL_PROXY_EBSAPP
key "ebskey.pem"
cert "ebscert.pem"
