ACE Routing Load-Balance problem
ricardoccnp2005
Community Member
I'm trying to configure a routing load-balance with Cisco ACE Module based on the following scenario:
local users has a router (R1) as it default gateway, this router (R1) has a default route to the VIP that represent the serverfarm with two linux servers that should be used for Data Shaping over the WAN. I need to balance the traffic over the two linux servers and not necessary over the WAN.
The problem is that when I set up the local network router default route to VIP the routing process simply stop work ! If I change the route to the real server ip address everything start working again without any problem.
Follow the configs:
Local network Router - Static route
ip route 0.0.0.0 255.255.255.0 10.0.0.1 (VIP address)
Follow the ACE configs:
access-list 100 line 8 extended permit ip any any
rserver host rout001
ip address 10.0.0.32
inservice
rserver host rout002
ip address 10.0.0.31
inservice
serverfarm host BLC_ROUTING
predictor leastconns
rserver rout001
inservice
rserver rout002
inservice
class-map match-any VIP
2 match virtual-address 10.0.0.1 any
class-map type management match-any mgmt
2 match protocol icmp any
3 match protocol telnet any
4 match protocol ssh any
policy-map type management first-match access
class mgmt
permit
policy-map type loadbalance first-match INT_router
class class-default
serverfarm BLC_ROUTING
policy-map multi-match VIP
class VIP
loadbalance vip inservice
loadbalance policy INT_router
loadbalance vip icmp-reply
interface vlan 6
bridge-group 10
access-group input 100
service-policy input access
service-policy input VIP
no shutdown
interface vlan 8
bridge-group 10
no shutdown
interface bvi 10
ip address 10.0.0.5 255.255.255.0
no shutdown
I tried to change some parameters like "transparent" at serverfarm config and change the "predictor" method to "hash address source" but there was no good results at all.
Anyone has any idea why this process is not working ?
Is there any special configuration for this scenario ?
Ricardo
blade_ace
Community Member
Your image shows the VIP and the default gateway have the same ip address. I think that might be your issue.
Did u try a static route in the router
ip route 10.0.0.0 255.255.255.0 10.0.0.5
with regards
sathappan.s
Gilles Dufour
Ricardo,
What is this route ??
You can't have 0.0.0.0/24.
You must be missing something ?
Also, since the vip is part of a vlan with subnet 10.0.0.0/24 you don't need to add a static route to reach that vip.
It should normally be directly connected to your router.
With the static route, do you see traffic coming to the ACE module ?
Does it loadbalance to the server ?
'show service-policy detail' check the packet counters
Gilles.
