ACE serverfarm total connections failures
cajalat
I have many server farms in various contexts and every single serverfarm shows something like this:
NDCD23ACERT1/Internal-1295# sh serverfarm FINPROD88_80 detail
serverfarm : FINPROD88_80, type: HOST
total rservers : 3
description : -
predictor : ROUNDROBIN
failaction : purge
total conn-dropcount : 0
----------connections-----------
real weight state current total
rserver: FINPRODAPP5
10.1.129.39:8320 2 OUTOFSERVICE 2 138
total conn-failures : 348
rserver: FINPRODAW1
10.1.129.29:8320 1 OPERATIONAL 25 179
total conn-failures : 418
rserver: FINPRODAW2
10.1.129.30:8320 1 OPERATIONAL 8 165
total conn-failures : 456
The conn-failures counter keeps growning on all of the farms. What exactly could be the problem? People aren't complaining but it bothers me to see those counters grow.
Casey
total conn-failures counter can increment due to several reasons
1. When Server sends RST to close the connection
2. When Client Sends an invalid HTTP request
3. If "persistence-rebalance" & "layer 7 class map" is configured and ACE doesnt find a L7 condition in client request.
So increments in the counter doesnt always means that there is a server problem :)
There are bugs reported for all the above conditions.I am not sure if they are fixed in the latest release.
Hope it helps
Syed
I'm running A1(6.2) and the numbers are extremely suspicious. I don't think they are correct. I have 52 farms configured and every single one is showing a significantly large number of conn-failures. Generally around 50% of total connections.
