ACE showing many connection failures on server farm
MICHAEL CICCONE
I just upgraded my ACE blade from A2(1.0 to A2(1.5a). After the upgrade I'm seeing an enormous amount of connection failures when I run the command show server xxx. Everything appears to be running fine. I can get to the web servers. I found an old posting and they reference Bug CSCsh1478, but when I looked at this bug the problem was corrected in version A2(1.0). Any ideas of what's going on?
Mike
Gilles Dufour
you will need to take a sniffer trace to see if there are any un-answered SYN or RST from the server.
Gilles.
Thanks for the reply. I'll try that out.
